    MagicMirror using the wrong time
    54 Posts 6 Posters 32.6k Views 6 Watching
      blissb @sdetweil
      I’m having some really odd problems with the raspbian install. Starting to wonder about the hardware. It’s a RPi 2B that’s been rock solid for years, but for whatever reason it won’t boot from any newly flashed SD card - though it boots fine from the original.
      I have another one in a box somewhere. I’ll pull it out and give it a try – I’d hate to think I’ve wasted your time over flakey hardware – but the fact that the other one is working as expected with the previous MM version makes me think (hope!) that’s not the case.
      I’ll definitely keep you posted!
        blissb @sdetweil
        I pulled out another Pi, flashed the OS and installed MM using the script you referenced earlier. It’s working perfectly. I’m still completely baffled. I’ve triple checked on the original SD image - it works as expected on the previous version of MM, but not on the current one… Ah well –
        Thank you for taking so much time to look into this, and I am sorry for having wasted so much of your time.
          sdetweil @blissb
          @blissb not wasted time, interesting problem.
          glad we’ve found something that resolves it.
          thank for your feedback
            jasonumd @sdetweil
            @sdetweil I’m chiming in a bit late here. Has there been any more widespread report of calendar times being off? Mine worked flawless for years then the past few months times are off, presumably UTC as mentioned in this thread.
            I’m having a hard time seeing what the actual solution was?
            Thanks so much in advance!
              sdetweil @jasonumd
              @jasonumd so far, every time events have been off, the system timezone has not been set correctly…
              note that a docker container is its own system and needs ITS timezone set too…
              what changed since it worked to now?
              J 2 Replies Last reply Reply Quote 0
                jasonumd @sdetweil
                @sdetweil I changed absolutely nothing. Just applied regular MM updates. I will investigate those two settings ASAP.
                • N Offline
                  n1sni @jasonumd
                  @jasonumd Same - I have been running this for years… and just did “git pull” and “npm update” in two separate module directories and now I’m UTC. “date” from the console shows the correct date/time.
                  Raspberry pi…
                  Linux mm 5.15.90-v7+ #1623 SMP Mon Jan 30 14:59:14 GMT 2023 armv7l GNU/Linux
                  Running the MagicMirror docker.
                    sdetweil @n1sni
                    @n1sni edit the docker container parms to add
                    environment:
                           TZ:your_timezone
                    else it defaults to UTC
                    • N Offline
                      n1sni @sdetweil
                      @sdetweil said in MagicMirror using the wrong time:
                      TZ=your_timezone
                      Wow, that was easy :)
                      Thank you!!
                      pi@mm:~/magicmirror/run $ pwd
                      /home/pi/magicmirror/run
                      pi@mm:~/magicmirror/run $ vi docker-compose.yml
                          devices:
                            - /dev/vchiq
                          environment:
                            DISPLAY: unix:0.0
                            TZ: America/New_York   # <- This line added
                          network_mode: host
                        jasonumd @sdetweil
                        @sdetweil I just confirmed my system timezone is accurate. I’m not running MM via docker. I set this up probably 4 years ago. Perhaps I should do a fresh install.
                          sdetweil @jasonumd
                          @jasonumd just for the sake of fun testing
                          in the script you use to start MM add
                          export TZ=????
                          where ??? is your timezone code
                          add this line before the
                          npm start
                          line
                          if you are using my install script with PM2, then the script located at
                          ~/MagicMirror/installers/mm.sh
                            jasonumd @sdetweil
                            @sdetweil I’m not a linux guru. Added and rebooted. but I’m operating via Putty. Am I supposed to reboot while watching the screen and check for something?
                              sdetweil @jasonumd
                              @jasonumd just seeing if MM reports correctly
                                sdetweil @jasonumd
                                @jasonumd didn’t need to reboot… if using pm2, then
                                pm2 status
                                pm2 restart xx
                                where x is the number of the line of the MagicMirror app
                                or the name shown on that same line (I set it up as MagicMirror, others get mm as they started mm.sh)
                                • 3 / 3
