    MMM-Lucy
    9 Posts 2 Posters 1.4k Views 2 Watching
    • C Offline
      Crimel
      Hi :)
      I’m trying to upgrade my Mirror with Lucy, but I’m failing mostly.
      Firstly I’ve followed the original way and installed everything without virtual env. - Did not work
      I noticed that a lot of stuff was missing, so I reworked the installation file today in an 4-hour shift, and now the installation dependencies.sh works like a charm.
      I changed some paths, included some checks… and some other stuff.
      After all, my efforts were not recognized by Lucy - she doesn’t like me… ^^
      I have tested my camera, microphone and speakers -everything works but not with Lucy.
      The screen starts like this (It even says ready for command few milliseconds"
      2 seconds later in changes
      I have tried a different voice module and my microphone worked…
      Meanwhile, I’m out of Ideas. I hope somebody has a solution ready
      I’m using Rasbian 64Bit on a Raspberry 4B+
      Appriciate your help!
      Cheers
      Chris
        sdetweil @Crimel
        @Crimel which raspian? latest? running Wayland ?
        • C Offline
          Crimel @sdetweil
          @sdetweil yes, running wayland, the most recent version
            sdetweil @Crimel
            @Crimel The audio system is completely different and lucy won’t work.
            Lucy needs pulse audio, and Wayland has pipeworks and they said that in their announcement.
            • C Offline
              Crimel @sdetweil
              @sdetweil I was thinking it would be enough to change it in the raspi-config to pulse not?
              Does this say you something?
                sdetweil @Crimel
                @Crimel I do not know. you can try
                C 2 Replies Last reply Reply Quote 0
                • C Offline
                  Crimel @sdetweil
                  Doesnt work, the mirror goes into a restart loop until I abbort it.
                  I tried today to install it also on a Raspi 3B+ with bullseye -> actually its even here not working. XQQ + Pulsaudio
                  The script went through but still having the Microphone errors.
                  Which OS do you have running for Lucy & could recommend me to make another test installation?
                  Cheers
                  • C Offline
                    Crimel @sdetweil
                    @sdetweil Forgot to add the Screnshot… sorry
                    Basically the same error on two different OS. :(
                      sdetweil @Crimel
                      @Crimel been years since I tried it.
