    Config option with array of multiple values?
    25 Posts 3 Posters 8.2k Views 3 Watching
      sdetweil @UncleRoger
      @UncleRoger well, maybe its even easier
      on the github page
      the link next to the branches
      you can rename main to xyz
      then rename master to main
      then delete xyz branch
      then on your pc
      rename the existing folder out of the way
      git clone your repo again
      then you will be in sync
      UncleRogerU 1 Reply Last reply Reply Quote 1
      • UncleRogerU Offline
        UncleRoger @sdetweil
        I went with your first suggestion and it seems to be all better now.
        I’m going to play with it some more but once I’m satisfied it won’t break anyone’s set up too badly, do I just change the visibility from private to public?
        There was a notice about the repository not being protected but it seems to have gone away; is that something I should worry about?
        Lastly, I see this on the repository page:
        Do I need to do anything about those?
        Thanks again for all your help and your patience!
          @UncleRoger just change it to public. the others are for bigger projects
            @sdetweil Thanks!
              UncleRoger @MZ-BER
              @MZ-BER
              FYI, I’ve published and posted in the modules/showcase forum.
              https://forum.magicmirror.builders/topic/18139/mmm-mailmessage-send-messages-to-your-magicmirror-via-e-mail?_=1698853756973
