Config option with array of multiple values?
25 Posts 3 Posters 4.5k Views 3 Watching
    sdetweil @UncleRoger
    @UncleRoger well, maybe its even easier
    on the github page
    the link next to the branches
    you can rename main to xyz
    then rename master to main
    then delete xyz branch
    then on your pc
    rename the existing folder out of the way
    git clone your repo again
    then you will be in sync
    U 1 Reply Last reply Oct 30, 2023, 5:17 PM Reply Quote 1
    • U Offline
      UncleRoger @sdetweil
      I went with your first suggestion and it seems to be all better now.
      I’m going to play with it some more but once I’m satisfied it won’t break anyone’s set up too badly, do I just change the visibility from private to public?
      There was a notice about the repository not being protected but it seems to have gone away; is that something I should worry about?
      Lastly, I see this on the repository page:
      Do I need to do anything about those?
      Thanks again for all your help and your patience!
      S 1 Reply Last reply Oct 30, 2023, 5:54 PM Reply Quote 0
        @UncleRoger just change it to public. the others are for bigger projects
        U 1 Reply Last reply Oct 30, 2023, 6:27 PM Reply Quote 1
        • U Offline
          @sdetweil Thanks!
          • U Offline
            UncleRoger @MZ-BER
            @MZ-BER
            FYI, I’ve published and posted in the modules/showcase forum.
            https://forum.magicmirror.builders/topic/18139/mmm-mailmessage-send-messages-to-your-magicmirror-via-e-mail?_=1698853756973
            • 3 / 3
            3 / 3
