    Error trying to run: npm run install-mm
    18 Posts 2 Posters 5.7k Views 2 Watching
    • L Offline
      lvolkjr @sdetweil
      @sdetweil I didn’t see any errors after running sudo apt-get remove nodejs -y
      When I run node -v I get this:
      bash: /usr/bin/node: No such file or directory
        sdetweil @lvolkjr
        @lvolkjr ok, do
        ls /usr/bin/node
        should return file not found
        do
        hash -r
        node -v
        just to make sure…
        then run my install or upgrade script as appropriate…
        • L Offline
          lvolkjr @sdetweil
          @sdetweil This is what I got:
          lowell@raspberrypi:~ $ ls /usr/bin/node
          ls: cannot access ‘/usr/bin/node’: No such file or directory
          lowell@raspberrypi:~ $ hash -r
          lowell@raspberrypi:~ $ node -v
          bash: node: command not found
          Do you still want me to run your script? I feel like node -v should have given me a different output, like the version number.
            sdetweil @lvolkjr
            @lvolkjr I expected something too
            I’d rebuild the SD card, boot, skip updates
            then use my script. this node install is such a mess, they changed the process…ugh
            • L Offline
              lvolkjr @sdetweil
              @sdetweil Yea, I figured. Thanks for all your help. Hopefully I could repay you in the future. I’ll keep you updated to what happens.
              • L Offline
                lvolkjr @lvolkjr
                @sdetweil Thanks!!! That worked! I’m running MagicMirror and getting ready to customize it. I should have started over a long time ago.
                  sdetweil @lvolkjr
                  @lvolkjr cool… yeh, its hard to tell when you’ve hit a real roadblock
                  glad you are working now… make sure to backup!!..
                  see https://github.com/sdetweil/MagicMirror-backup-restore
                  • L Offline
                    lvolkjr @sdetweil
                    @sdetweil I will, thanks again.
