    Trouble using pm2 to install modules
    5 Posts 2 Posters 1.6k Views 2 Watching
    • V Offline
      vandam3b
      Hi, I can not seem to load and modules. I reinstalled MM using the script but now no modules will load. Here is what I out in and the information I get back. Any help would be appreciated. I tried 3 different modules with no success. Thank you
      vandam3b@raspberrypi:~ $ cd MagicMirror
      vandam3b@raspberrypi:~/MagicMirror $ cd modules
      vandam3b@raspberrypi:~/MagicMirror/modules $ https://github.com/jclarke0000/MMM-MyScoreboard.git
      bash: https://github.com/jclarke0000/MMM-MyScoreboard.git: No such file or directory
      vandam3b@raspberrypi:~/MagicMirror/modules $ pm2 install https://github.com/jclarke0000/MMM-MyScoreboard.git
      [PM2][Module] Installing NPM https://github.com/jclarke0000/MMM-MyScoreboard.git module
      [PM2][Module] Module already installed. Updating.
      Deleting /home/vandam3b/.pm2/modules/MMM-MyScoreboard
      [PM2][Module] Calling [NPM] to install https://github.com/jclarke0000/MMM-MyScoreboard.git …
      added 39 packages in 22s
      1 package is looking for funding
      run npm fund for details
      [PM2][Module] Module downloaded
      ENOENT: no such file or directory, open ‘/home/vandam3b/.pm2/modules/MMM-MyScoreboard/node_modules/MMM-MyScoreboard/package.json’
      node:internal/modules/cjs/loader:1051
      throw err;
      Error: Cannot find module ‘/home/vandam3b/.pm2/modules/MMM-MyScoreboard/node_modules/MMM-MyScoreboard/package.json’
      Require stack:
      • /usr/local/lib/node_modules/pm2/lib/API/Modules/NPM.js
      • /usr/local/lib/node_modules/pm2/lib/API/Modules/Modularizer.js
      • /usr/local/lib/node_modules/pm2/lib/API.js
      • /usr/local/lib/node_modules/pm2/lib/binaries/CLI.js
      • /usr/local/lib/node_modules/pm2/bin/pm2
        at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
        at Module._load (node:internal/modules/cjs/loader:901:27)
        at Module.require (node:internal/modules/cjs/loader:1115:19)
        at require (node:internal/modules/helpers:130:18)
        at StartModule (/usr/local/lib/node_modules/pm2/lib/API/Modules/NPM.js:343:22)
        at /usr/local/lib/node_modules/pm2/lib/API/Modules/NPM.js:257:7
        at /usr/local/lib/node_modules/pm2/lib/Configuration.js:68:14
        at FSReqCallback.oncomplete (node:fs:189:23) {
        code: ‘MODULE_NOT_FOUND’,
        requireStack: [
        ‘/usr/local/lib/node_modules/pm2/lib/API/Modules/NPM.js’,
        ‘/usr/local/lib/node_modules/pm2/lib/API/Modules/Modularizer.js’,
        ‘/usr/local/lib/node_modules/pm2/lib/API.js’,
        ‘/usr/local/lib/node_modules/pm2/lib/binaries/CLI.js’,
        ‘/usr/local/lib/node_modules/pm2/bin/pm2’
      Node.js v20.8.0
        sdetweil @vandam3b
        @vandam3b you don’t use pm2 to install modules…
        you use npm
        npm reads the package.json file to determine what libraries to install.
        if there is no package.json then there is no install to do.
        pm2, is node process manager. it’s job is to start and keep applications ruining.
        • V Offline
          vandam3b
          Thanks and i down loaded a module but now I get this error.
          vandam3b@raspberrypi:~ $ pm2 start MagicMirror
          [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
          [PM2] MagicMirror ✓
          [PM2] Process successfully started
          │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
          │ 1 │ MM │ fork │ 369 │ online │ 131.8% │ 41.3mb │
          │ 0 │ MagicMirror │ fork │ 137 │ online │ 0% │ 4.6mb │
          I looked for the MM folder but can not find it. It was working before I installed the module. This is what the config. looks like.
          /* MagicMirror² Config Sample
          • By Michael Teeuw https://michaelteeuw.nl
          • MIT Licensed.
          • For more information on how you can configure this file
          • see https://docs.magicmirror.builders/configuration/introduction.html
          • and https://docs.magicmirror.builders/modules/configuration.html
          • You can use environment variables using a config.js.template file instead of config.js
          • which will be converted to config.js while starting. For more information
          • see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
            let config = {
            address: “localhost”, // Address to listen on, can be:
            // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
            // - “0.0.0.0”, “::” to listen on any interface
            // Default, when address config is left out or empty, is “localhost”
            port: 8080,
            basePath: “/”, // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
            ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
            // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
            // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
            useHttps: false, // Support HTTPS or not, default “false” will use HTTP
            httpsPrivateKey: “”, // HTTPS private key path, only require when useHttps is true
            httpsCertificate: “”, // HTTPS Certificate path, only require when useHttps is true
            language: “en”,
            locale: “en-US”,
            logLevel: [“INFO”, “LOG”, “WARN”, “ERROR”], // Add “DEBUG” for even more logging
            timeFormat: 24,
            units: “metric”,
            module: “alert”,
            module: “updatenotification”,
            position: “top_bar”
            module: “clock”,
            position: “top_left”
            module: “calendar”,
            header: “US Holidays”,
            position: “top_left”,
            symbol: “calendar-check”,
            url: “https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics”
            module: “compliments”,
            position: “top_bar”
            module: ‘MMM-3Day-Forecast’,
            position: ‘top_right’,
            api_key: ‘e40b2a1224254edcecde9ccbc165c869’,
            lat: 40.658421,
            lon: -74.299593,
            units: ‘I’,
            lang: ‘en’,
            interval: 900000,
             	module: "weather",
             	position: "",
             	header: "Weather Forecast",
             		type: "forecast",
             		locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
             		apiKey: "YOUR_OPENWEATHER_API_KEY"
             	module: "newsfeed",
             	position: "bottom_bar",
             		feeds: [
             				title: "Sports",
             				url:"https://api.foxsports.com/v2/content/optimized-rss?partnerKey=MB0Wehpmuj2lUhuRhQaafhBjAJqaPU244mlTDK1i&tags=fs/cfb&size=30"
             		showSourceTitle: true,
             		showPublishDate: true,
             		broadcastNewsFeeds: true,
             		broadcastNewsUpdates: true
          if (typeof module !== “undefined”) {module.exports = config;}
            sdetweil @vandam3b
            @vandam3b the process of installing modules is the same 100% of
            the time
            regardless of what the author documents
            cd ~/MagicMirror/modules
            git clone the_github_url_of_the_new_module
            cd  the_modulename  (exact case)
            if there is a file called package.json , then do
            npm install
            then add the module config entry to the list in ~/MagicMirror/config/config.js
            then restart MagicMirror
            I suggest using the npm start approach on first start after adding a module so that you can debug any issues quickly, without pm2 involvement. … then use pm2 for production again
            • V Offline
              vandam3b
              Thanks you. I appreciate it.
