    Mmm calendar ext3
    11 Posts 3 Posters 7.3k Views 3 Watching
      Michelle.H2020
      How can I change the cell height and width as well as show the whole event not just the first letter on my calendar ? I am new so if you could explain it easily anything will help!
        MMRIZE @Michelle.H2020
        @Michelle-H2020
        Only first letter? Show me a picture of your mirror. And your config also be needed to guess what happened.
        Of course the small resolution cannot handle enough width of module.
          Michelle.H2020 @MMRIZE
          @MMRIZE
          https://share.icloud.com/photos/03aqlgKBfgMhJNo1eFLv7-Jng
            sdetweil
            @Michelle-H2020 please use the code block around config info
              Michelle.H2020 @sdetweil
                module: "MMM-CalendarExt3",
                position: "bottom_bar",
              mode: "week",
                  instanceId: "basicCalendar",
                  locale: 'en',
                  maxEventLines: 4,
              url: "https://calendar.google.com/calendar/ical/dandmfloors2023%40gmail.com/public/basic.ics",
              maxTitleLength: 50,
                  firstDayOfWeek: 1,
                 weeksInView: 3,
              wrapEvents: true,
              timeFormat: "relative",
              		dateFormat: "MMM Do",
              		dateEndFormat: "LT",
              		fullDayEventDateFormat: "MMM Do",
              weekIndex:0,
              useWeather: true,
              weatherLocationName: "castle rock",
              displayWeatherTemp: true,
              			header: "D and M floors",
              			position: "middle",
              				broadcastPastEvents: true,
              maxTitleLength: 50,
              fade: false,
              						symbol: "heart",
              						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
              						url: "https://calendar.google.com/calendar/ical/9953584ecf47252ac2c45157fea7937266a498edfa2520dbfaccd8778cec2833%40group.calendar.google.com/public/basic.ics",
                sdetweil @Michelle.H2020
                @Michelle-H2020 said in Mmm calendar ext3:
                module: “calendar”,
                header: “D and M floors”,
                position: “middle”,
                in the default calendar
                the calendars:[ ] // is a list
                each entry in the list is a url block
                     url:
                     color:
                     name:
                     symbol:
                if TWO of the same entry is made ( like url, and url), the second overlays the first…
                ext3 NEVER uses url…
                  @Michelle-H2020
                  What is your screen resolution? It seems not FHD.
                    @Michelle-H2020
                    I think you probably edited custom.css,
                    Without any modification/overriding of custom.css, This module should look like these;
                    • 1080x1920 vertical screen
                    • 600x800 vertical screen
                      @MMRIZE
                      Great I will mess around with that when I get home later also how did you change your calendar event to showing just todays events ? Mine show all the way until January trying to resolve that.
                      Also I have just been adjusting the config.is file I have no idea about the css stuff yet . Is that where you go to change font and styles ?
                        I was wondering why it wasn’t showing both my calendars thanks ! I will mess with that when I get home
                          Michelle.H2020
                          So I think I’m ok with the bottom calendar I just can’t figure out how to make the list to display for a month instead of all the way into January
                          https://share.icloud.com/photos/078is2God3mgkrI_9spjrgJ5g
