    ERROR:gbm_wrapper.cc(253) Failed to export buffer to dma_buf: No such file or directory
    15 Posts 3 Posters 12.3k Views 3 Watching
      rrslssr
      This would seem to be a minor irritation rather than an issue, but…
      My system was installed using @sdetweil’s installation script.
      MM seems to be working and displaying properly on my system:
      • Linux magicmirror 6.1.0-rpi6-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.58-1+rpt2 (2023-10-27) aarch64 GNU/Linux
      • /bin/bash: ELF 64-bit LSB pie executable, ARM aarch64, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, BuildID[sha1]=198ac6b0cc01bf774c5746a36a6fd31dead9bda5, for GNU/Linux 3.7.0, stripped
      However, I get these errors are displayed quickly after starting MM:
      [13.11.2023 12:28.38.427] [LOG] Launching application.
      [6982:1113/122839.369692:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [6982:1113/122839.371506:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [6982:1113/122839.372947:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [6982:1113/122839.374394:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [6982:1113/122839.375867:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [6982:1113/122839.377332:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [6982:1113/122839.378891:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [6982:1113/122839.382146:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [6982:1113/122839.383645:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [6982:1113/122839.385641:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [6982:1113/122839.388818:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [6982:1113/122839.390166:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [6982:1113/122839.392742:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [6982:1113/122839.395676:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      Are these errors something I should worry about and correct, or can I just ignore them?
      Thanks.
        rrslssr
        @sdetweil said in ERROR:gbm_wrapper.cc(253) Failed to export buffer to dma_buf: No such file or directory:
        export ELECTRON_DISABLE_GPU=1
        @sdetweil That did not work for those errors, but it did eliminate other errors further down.
        I’ll just ignore these.
          sdetweil @rrslssr
          @rrslssr you can ignore them,
          OR add
          before the npm start line in
          ~/MagicMirror/installers/mm.sh
            rrslssr
            • E ereborinkorppi referenced this topic on
              dathbe @sdetweil
              Is this still the right way to address these errors? This is what my ~/MagicMirror/installers/mm.sh file looks like:
              #!/bin/bash
              cd /home/mmuser/MagicMirror
              if [ $(ps -ef | grep -v grep | grep -e wayfire -e labwc | wc -l) -ne 0 ]; then
                 WAYLAND_DISPLAY=wayland-1
                 npm run start:wayland
              else
                 DISPLAY=:0 npm start
              fi
              And I’m still getting the following errors:
              0|mm  | [2154:0415/185345.685943:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.686603:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
              0|mm  | [2154:0415/185345.689774:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.690194:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
              0|mm  | [2154:0415/185345.690550:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.690714:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
              0|mm  | [2154:0415/185345.690957:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.691151:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
              0|mm  | [2154:0415/185345.692895:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.693152:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
              0|mm  | [2154:0415/185345.693449:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.693628:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
              0|mm  | [2154:0415/185345.693878:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.694076:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
              0|mm  | [2154:0415/185345.694390:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.694612:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
              0|mm  | [2154:0415/185345.696528:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.696838:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
              0|mm  | [2154:0415/185345.697254:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.697494:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
              0|mm  | [2154:0415/185345.697824:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.698209:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
              0|mm  | [2154:0415/185345.698617:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.698851:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
              0|mm  | [2154:0415/185345.699185:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.699426:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
              0|mm  | [2154:0415/185345.699753:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.700002:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
              0|mm  | [2154:0415/185345.700357:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.700604:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
              0|mm  | [2154:0415/185345.701001:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: No such file or directory (2)
              0|mm  | [2154:0415/185345.701225:ERROR:gbm_wrapper.cc(261)] Failed to export buffer to dma_buf: No such file or directory (2)
                sdetweil @dathbe
                @dathbe I tried to make it dynamically select, but that didn’t work, so its commented out
                ‘’’ is a bash block comment
                someone posted that npm run start:wayland worked for them to clear those errors…
                  sdetweil @dathbe
                  @dathbe said in ERROR:gbm_wrapper.cc(253) Failed to export buffer to dma_buf: No such file or directory:
                  the default now is disabled…
                  and the env var has changed to
                  export ELECTRON_ENABLE_GPU=1
                  to turn it on
                    dathbe @sdetweil
                    No luck. with DISPLAY=:0 npm start, I get the long list of errors, but everything seems to work ok with the mirror. with
                    It throws other errors and gets stuck in what seems to be a restart loop.
                    0|mm  | [3351:0415/211257.942494:ERROR:wayland_connection.cc(199)] Failed to connect to Wayland display: No such file or directory (2)
                    0|mm  | [3351:0415/211257.942729:ERROR:ozone_platform_wayland.cc(276)] Failed to initialize Wayland platform
                    0|mm  | [3351:0415/211257.942774:ERROR:env.cc(257)] The platform failed to initialize.  Exiting.
                    0|mm  | /home/mmuser/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                      sdetweil @dathbe
                      @dathbe yeh, thats what I found too…
                      maybe its labwc display now?
                      from the labwc doc,
                      https://labwc.github.io/labwc-config.5.html
                      it sounds like DISPLAY is the correct variable
                      The autostart file is executed as a shell script after labwc has read its configuration and set variables defined in the environment file. Additionally, the environment variables WAYLAND_DISPLAY and (when labwc is built with Xwayland support) DISPLAY will be defined
                        dathbe @sdetweil
                        I tried all three options in raspi-config > Advanced > Wayland (those being 1) X11, 2) Wayfire, and 3) Labwc), and was getting the same error on all of them. I went back to Labwc because my understanding is that is the current recommended.
                        I’ve tried many different combinations. Anything having to do with start:wayland seems to truly fail and get stuck in a restart loop. npm run start:wayland technically works, but throws about 20 ugly error messages on start.
                        Various options I’ve tried:
                        # Work with error messages
                        # Cause endless start loop
                        DISPLAY=wayland-1
                          sdetweil @dathbe
                          @dathbe restart loop is pm2, its job is to keep the app running
                            dathbe @sdetweil
                            @sdetweil Ok. When I have some time, I’m going to test an install with 32-bit PiOS.
                              sdetweil @dathbe
                              @dathbe 32bit is x11 only . as i recall
                                dathbe @sdetweil
                                @sdetweil It appears to load labwc by default, but either way it didn’t do anything different – fails to start with start:wayland and multiple phantom errors with start. I guess I just have to close my eyes and not read the logs on startup. Though weird it’s doing it with my Pi 4B, but not my Pi 2B.
                                  sdetweil @dathbe
                                  @dathbe yeh some config setup, i think something in /boot/config. txt
                                    dathbe @sdetweil
                                    @sdetweil In case for some reason it’s helpful, I’ve reviewed the contents of /boot/config.txt from my two devices (4B gets errors, 2B does not).
                                    In 2B, not in 4B:
                                    #dtoverlay=vc4-kms-v3d
                                    # see https://forums.raspberrypi.com/viewtopic.php?p=1507622#p1507247
                                    dtoverlay=vc4-fkms-v3d
                                    In 4B, not in 2B:
                                    # Run in 64-bit mode
                                    arm_64bit=1
                                    [cm5]
                                    dtoverlay=dwc2,dr_mode=host
