    Jenkins RSS feed
    15 Posts 2 Posters 13.9k Views 2 Watching
      BeatIdo
      I’m testing news feed default plugin to read a local Jenkins feed.
      Looks good from a stand-alone reader but it seems I’ve got some parsing error retrieving the feed.
      I also tested with MMM-RSS-FEED but I don’t even get an error message like the one I got with news feed plugin.
      Has anyone tested this ?
      Thanks.
      Regards,
      Fred.
      Here is the error message :
      Create new news fetcher for url: http://xxx.xxx.xxx.xxx:8080/rssAll - Interval: 300000
      Whoops! There was an uncaught exception…
      TypeError: parser.close is not a function
      at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/lib/xmlfeedparser.js:107:14)
      at emitOne (events.js:96:13)
      at SAXStream.emit (events.js:188:7)
      at Object.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
      at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:640:35)
      at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:645:5)
      at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:841:5)
      at Object.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1294:15)
      at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
      at yoshi.write (/home/pi/MagicMirror/node_modules/feedme/lib/feedme.js:41:14)
        BeatIdo
        following this :
        it seems I got through this …
        parser.emit(‘error’, new Error(‘Feed type not recognized’));
        Feed format is xml version=“1.0” encoding="UTF-8
        and main markup is feed xmlns=“http://www.w3.org/2005/Atom”
          BeatIdo
          Using console.log I got confirmation that node.name is recognized as “html” where it should be “channel”, “feed” or “rss” according to the following function.
          I don’t know yet if Jenkins feed is malformed or if module parsing is mistaken.
          var openf1 = function(node) {
          var type;
          if (node.name === ‘channel’ || node.name === ‘feed’) {
          if (node.name === ‘feed’) {
          type = ‘atom’;
          obj.type = type;
          this.emit(‘type’, type);
          parser.removeListener(‘opentag’, openf1);
          parser.on(‘text’, ontext);
          parser.on(‘cdata’, ontext);
          parser.on(‘opentag’, onopentag);
          parser.on(‘closetag’, onclosetag);
          } else if (node.name === 'rss') {
            type = 'rss ' + node.attributes.version;
            obj.type = type;
            this.emit('type', type);
          } else {
            parser.emit('error', new Error('Feed type not recognized'));
            parser.close();
            roramirez Core Contributors
            Please shared your configuration and RSS output. The rss is in http://xxx.xxx.xxx.xxx:8080/rssAll ?
            Easy module development with MagicMirror Module Template
              BeatIdo @roramirez
              @roramirez here is my configuration, considering I also obfuscated my server IP and I switched to Jenkins failed build RSS feed. I hoped to get some content but theses feeds only sends article titles …
              Jenkins provides three global feeds respectively for all (rssAll), falied (rssFailed) and latest (rssLatest) builds at its base URL plus others for each configured job …
              By the way I checked that read access is open for anonymous connection by using a local RSS reader (RSSOwl) and it works well.
              Thanks for your help.
              /* Magic Mirror Config Sample
              • By Michael Teeuw http://michaelteeuw.nl
              • MIT Licensed.
              var config = {
              port: 8080,
              ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”,],
                  language: 'en',
                  timeFormat: 24,
                  units: 'metric',
                                  module: 'alert',
                                  module: "updatenotification",
                                  position: "top_bar"
                                  module: 'newsfeed',
                                  position: 'top_bar',
                                          feeds: [
                                                  title: "Jenkins RSS Failed",
                                                  url: "http://xxx.xxx.xxx.xxx:8080/rssFailed",
              if (typeof module !== ‘undefined’) {module.exports = config;}
                I found a public RSS, its can be help for test
                Can you test the follow URL?
                https://hub.spigotmc.org/jenkins/rssAll
                  Also, A rssFailed http://jenkins.movingblocks.net/rssFailed
                    BeatIdo
                    Retrieving MovinBlocks feed worked fine :)
                    On the other hand, SpigotMC feed prompted a certificate error. I’m not sure this may be caused by my proxy.
                    Of course I still got a parsing error accessing my own Jenkins feed.
                    Thanks for you quick answer.
                    Regards,
                    Fred.
                    Here is the error message I got from SpigotMC :
                    Ready to go! Please point your browser to: http://localhost:8080
                    Create new news fetcher for url: https://hub.spigotmc.org/jenkins/rssAll - Interval: 300000
                    { Error: unable to get local issuer certificate
                        at Error (native)
                        at TLSSocket. (_tls_wrap.js:1079:38)
                        at emitNone (events.js:86:13)
                        at TLSSocket.emit (events.js:185:7)
                        at TLSSocket._finishInit (_tls_wrap.js:603:8)
                        at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:433:38) code: 'UNABLE_TO_GET_ISSUER_CERT_LOCALLY' }
                    { Error: socket hang up
                        at createHangUpError (_http_client.js:254:15)
                        at TLSSocket.socketCloseListener (_http_client.js:286:23)
                        at emitOne (events.js:101:20)
                        at TLSSocket.emit (events.js:188:7)
                        at _handle.close (net.js:498:12)
                        at Socket.done (_tls_wrap.js:325:7)
                        at Socket.g (events.js:291:16)
                        at Socket.emit (events.js:188:7)
                        at TCP._handle.close [as _onclose] (net.js:498:12) code: 'ECONNRESET' }
                    fatal: unable to access 'https://github.com/MichMich/MagicMirror/': Failed to connect to github.com port 443: Connection timed out
                    Here is also the configuration I used, commenting alternatively each feed :
                                        module: 'newsfeed',
                                                feeds: [
                                                //        title: "Jenkins SpigotMC RSS All",
                                                //        url: "https://hub.spigotmc.org/jenkins/rssAll",
                                                //        title: "Jenkins MovingBlocks RSS Failed",
                                                //        url: "http://jenkins.movingblocks.net/rssFailed",
                                                        url: "http://10.195.154.232:8080/rssFailed",
                      BeatIdo
                      I’m wondering if the problem could be some entries have no content field ?
                      [Edit]
                      Actually is does not MovingBlocks feed has both entries with and without content field and all of them are well displayed.
                        BeatIdo
                        Eventually “link” markups are formatted in a different order between terasology server and mine but I doubt that would be the problem …
                        alternate field at the end or the beginning …
                        link rel=“alternate” type=“text/html” href=“http://jenkins.terasology.org/”/
                        link type=“text/html” href=“http://xxx.xxx.xxx.xxx:8080/” rel=“alternate”/
                        also my URL contains an IP and not a server name …
