Jenkins RSS feed
15 Posts 2 Posters 13.6k Views 2 Watching
    BeatIdo
    I’m testing news feed default plugin to read a local Jenkins feed.
    Looks good from a stand-alone reader but it seems I’ve got some parsing error retrieving the feed.
    I also tested with MMM-RSS-FEED but I don’t even get an error message like the one I got with news feed plugin.
    Has anyone tested this ?
    Thanks.
    Regards,
    Fred.
    Here is the error message :
    Create new news fetcher for url: http://xxx.xxx.xxx.xxx:8080/rssAll - Interval: 300000
    Whoops! There was an uncaught exception…
    TypeError: parser.close is not a function
    at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/lib/xmlfeedparser.js:107:14)
    at emitOne (events.js:96:13)
    at SAXStream.emit (events.js:188:7)
    at Object.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
    at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:640:35)
    at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:645:5)
    at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:841:5)
    at Object.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1294:15)
    at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
    at yoshi.write (/home/pi/MagicMirror/node_modules/feedme/lib/feedme.js:41:14)
      BeatIdo
      following this :
      it seems I got through this …
      parser.emit(‘error’, new Error(‘Feed type not recognized’));
      Feed format is xml version=“1.0” encoding="UTF-8
      and main markup is feed xmlns=“http://www.w3.org/2005/Atom”
        BeatIdo
        Using console.log I got confirmation that node.name is recognized as “html” where it should be “channel”, “feed” or “rss” according to the following function.
        I don’t know yet if Jenkins feed is malformed or if module parsing is mistaken.
        var openf1 = function(node) {
        var type;
        if (node.name === ‘channel’ || node.name === ‘feed’) {
        if (node.name === ‘feed’) {
        type = ‘atom’;
        obj.type = type;
        this.emit(‘type’, type);
        parser.removeListener(‘opentag’, openf1);
        parser.on(‘text’, ontext);
        parser.on(‘cdata’, ontext);
        parser.on(‘opentag’, onopentag);
        parser.on(‘closetag’, onclosetag);
        } else if (node.name === 'rss') {
          type = 'rss ' + node.attributes.version;
          obj.type = type;
          this.emit('type', type);
        } else {
          parser.emit('error', new Error('Feed type not recognized'));
          parser.close();
          roramirez Core Contributors
          Please shared your configuration and RSS output. The rss is in http://xxx.xxx.xxx.xxx:8080/rssAll ?
          B 1 Reply Last reply Feb 21, 2017, 5:30 PM Reply Quote 0
            BeatIdo @roramirez
            @roramirez here is my configuration, considering I also obfuscated my server IP and I switched to Jenkins failed build RSS feed. I hoped to get some content but theses feeds only sends article titles …
            Jenkins provides three global feeds respectively for all (rssAll), falied (rssFailed) and latest (rssLatest) builds at its base URL plus others for each configured job …
            By the way I checked that read access is open for anonymous connection by using a local RSS reader (RSSOwl) and it works well.
            Thanks for your help.
            /* Magic Mirror Config Sample
            • MIT Licensed.
            var config = {
            port: 8080,
            ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”,],
                language: 'en',
                timeFormat: 24,
                units: 'metric',
                                module: 'alert',
                                module: "updatenotification",
                                position: "top_bar"
                                module: 'newsfeed',
                                position: 'top_bar',
                                        feeds: [
                                                title: "Jenkins RSS Failed",
                                                url: "http://xxx.xxx.xxx.xxx:8080/rssFailed",
            if (typeof module !== ‘undefined’) {module.exports = config;}
              I found a public RSS, its can be help for test
              Can you test the follow URL?
              https://hub.spigotmc.org/jenkins/rssAll
                Also, A rssFailed http://jenkins.movingblocks.net/rssFailed
                  BeatIdo
                  Retrieving MovinBlocks feed worked fine :)
                  On the other hand, SpigotMC feed prompted a certificate error. I’m not sure this may be caused by my proxy.
                  Of course I still got a parsing error accessing my own Jenkins feed.
                  Thanks for you quick answer.
                  Regards,
                  Fred.
                  Here is the error message I got from SpigotMC :
                  Ready to go! Please point your browser to: http://localhost:8080
                  Create new news fetcher for url: https://hub.spigotmc.org/jenkins/rssAll - Interval: 300000
                  { Error: unable to get local issuer certificate
                      at Error (native)
                      at TLSSocket. (_tls_wrap.js:1079:38)
                      at emitNone (events.js:86:13)
                      at TLSSocket.emit (events.js:185:7)
                      at TLSSocket._finishInit (_tls_wrap.js:603:8)
                      at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:433:38) code: 'UNABLE_TO_GET_ISSUER_CERT_LOCALLY' }
                  { Error: socket hang up
                      at createHangUpError (_http_client.js:254:15)
                      at TLSSocket.socketCloseListener (_http_client.js:286:23)
                      at emitOne (events.js:101:20)
                      at TLSSocket.emit (events.js:188:7)
                      at _handle.close (net.js:498:12)
                      at Socket.done (_tls_wrap.js:325:7)
                      at Socket.g (events.js:291:16)
                      at Socket.emit (events.js:188:7)
                      at TCP._handle.close [as _onclose] (net.js:498:12) code: 'ECONNRESET' }
                  fatal: unable to access 'https://github.com/MichMich/MagicMirror/': Failed to connect to github.com port 443: Connection timed out
                  Here is also the configuration I used, commenting alternatively each feed :
                                      module: 'newsfeed',
                                              feeds: [
                                              //        title: "Jenkins SpigotMC RSS All",
                                              //        url: "https://hub.spigotmc.org/jenkins/rssAll",
                                              //        title: "Jenkins MovingBlocks RSS Failed",
                                              //        url: "http://jenkins.movingblocks.net/rssFailed",
                                                      url: "http://10.195.154.232:8080/rssFailed",
                  R 1 Reply Last reply Feb 23, 2017, 10:06 PM Reply Quote 0
                    BeatIdo
                    I’m wondering if the problem could be some entries have no content field ?
                    [Edit]
                    Actually is does not MovingBlocks feed has both entries with and without content field and all of them are well displayed.
                      BeatIdo
                      Eventually “link” markups are formatted in a different order between terasology server and mine but I doubt that would be the problem …
                      alternate field at the end or the beginning …
                      link rel=“alternate” type=“text/html” href=“http://jenkins.terasology.org/”/
                      link type=“text/html” href=“http://xxx.xxx.xxx.xxx:8080/” rel=“alternate”/
                      also my URL contains an IP and not a server name …
                      B 1 Reply Last reply Feb 23, 2017, 12:49 PM Reply Quote 0
