    Problems with Python3 and RPi.GPIO under root
    2 Posts 2 Posters 582 Views 2 Watching
    • M
      MyMirror
      Hi all,
      may i ask for a little help?
      I am really not a Linux specialist and would be glad if you could help me with this problem.
      Environment: Raspi 3b with Bullseye
      uname -a gives the following output: Linux MM3 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
      Version of my MagicMirror: 2.25.0
      If I start Python3 as normal user “pi” and call “import RPi.GPIO as GPIO”, then it works but not as root:
      pi@MM3:~/MagicMirror $ pwd
      /home/pi/MagicMirror
      pi@MM3:~/MagicMirror $ whoami
      pi
      pi@MM3:~/MagicMirror $ python3
      Python 3.9.7 (default, Oct 14 2023, 17:06:45)
      [GCC 10.2.1 20210110] on linux
      Type "help", "copyright", "credits" or "license" for more information.
      pi@MM3:~/MagicMirror $ su - root
      Passwort:
      root@MM3:~# pwd
      /root
      root@MM3:~# python3
      Traceback (most recent call last):
        File "<stdin>", line 1, in <module>
      ModuleNotFoundError: No module named 'RPi'
      root@MM3:~
      Unfortunately, I cannot start such a python script for a PIR as a service. What is the user root missing that the user “pi” has?
      I want the Python script here: /lib/systemd/system to start as a service when starting the raspi: pir_sensor.service This is not done with the user “pi” but as “root” or “system”, right?
      Contents of pir_sensor.service:
      [Unit]
      Description=MagicMirror PIR Service
      After=multi-user.target
      [Service]
      Type=idle
      WorkingDirectory=/home/pi/MagicMirror
      Restart=on-failure
      User=root
      ExecStart=/usr/bin/python3.9 /home/pi/MagicMirror/pirx.py
      [Install]
      WantedBy=multi-user.target
      And the start of my pirx.py looks like this:
      #!/usr/bin/python3
      # coding: utf8 #
      As user pi it works well, but as described above, not as root or “system”.
      Can anyone help me to repair Python to work under root/system as well with RPi.GPIO?
      Jens
        sdetweil @MyMirror
        @MyMirror use pm2 to launch your script. it will launch as the user
        see pm2 --help
        after the appropriate pm2 start
        do pm2 save
        to have that task launched at boot
