    Google Keep setup
    8 Posts 4 Posters 1.7k Views 4 Watching
    • C
      csongor.varga 0
      Hi All,
      I am trying to set up Google Keep and I use the MMM-GoogleKeep module. This seems to have worked for most, but I am not able to pass the Google Authentication part.
      I can see a message in the log that the module required authentication, but when I click on that and I try to go through the steps I get a never ending “One moment please” error.
      There is an issue on GitHub and based on response it has been resolved, by I wonder if it is broken again.
      I use 2FA and created and app password for this.
      Has one of you set this up recently?
        sdetweil @csongor.varga 0
        @csongor-varga-0 you must do this ON the MM system, cannot do it over ssh
        C 1 Reply Last reply
        • C
          csongor.varga 0 @sdetweil
          @sdetweil Yes,I did that. I mean I was checking the log messages on the main console screen, copied the URL and pasted it into the standard raspbian browser.
          Also as a side question: when I create the app password, it is a 16 letter code in groups on 4. Do you enter that into the config file with spaces after each 4 letter group or not? Or it makes no difference.
            @csongor-varga-0 i do not know the module design… so not sure…
            • C
              csongor.varga 0
              If anyone managed to get this module working recently, please let me know because I can’t get passed the errors no matter what I do.
              A 1 Reply Last reply
              • A
                ashna @csongor.varga 0
                @csongor-varga-0 did you manage to get this to work?
                • M
                  MMRIZE
                  As far as I know, Google Keep API works only under enterprise environments, so personal/private user cannot use it.
                  • A
                    ashna @MMRIZE
                    @MMRIZE thank you I am still failing miserably at getting the gkeepapi to work with the mmm google keep module. It’s been 10 days of Me working on it no luck
