    Magic Mirror doesn't work after a boot
    27 Posts 2 Posters 7.1k Views 2 Watching
      sdetweil @eightbit
      @eightbit also do a
      free -m
      see how big the swap space is and total memory
      • E Offline
        eightbit @sdetweil
        @sdetweil Raspberry Pi 3 Model B Rev 1.2
        I did try to use systemd but it did not work so I disabled and deleted all the systemd attempts.
        • E Offline
          eightbit @sdetweil
          secretsanta@raspberrypi:~ $ free -m
                         total        used        free      shared  buff/cache   available
          Mem:             921         265          94           6         561         594
          Swap:           1861           1        1860
            sdetweil @eightbit
            @eightbit can u show me the “start”: from package.json
            E 1 Reply Last reply Reply Quote 1
            • E Offline
              eightbit @sdetweil
                 "start":"./run-start.sh $1",
                             "server": "node ./serveronly",
                             "install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
                             "install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
                             "install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                             "install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                             "postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installation finished successfully! \n\"",
                             "test": "NODE_ENV=test jest -i --forceExit",
                             "test:coverage": "NODE_ENV=test jest --coverage -i --verbose false --forceExit",
                             "test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
                             "test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
                             "test:unit": "NODE_ENV=test jest --selectProjects unit",
                             "test:prettier": "prettier . --check",
                             "test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --confi>
                             "test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
                             "test:calendar": "node ./modules/default/calendar/debug.js",
                             "config:check": "node js/check_config.js",
                             "lint:prettier": "prettier . --write",
                             "lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --confi>
                             "lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
                             "lint:staged": "lint-staged",
                             "prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed."
                sdetweil @eightbit
                @eightbit
                delete one of them and replace the other with
                		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
                also do uname -a
                E 2 Replies Last reply Reply Quote 1
                • E Offline
                  eightbit @sdetweil
                  @sdetweil said in Magic Mirror doesn't work after a boot:
                  “start”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js”,
                          "name": "magicmirror",
                          "version": "2.25.0",
                          "description": "The open source modular smart mirror platform.",
                          "main": "js/electron.js",
                          "scripts": {
                          "repository": {
                                  "type": "git",
                                  "url": "git+https://github.com/MichMich/MagicMirror.git"
                  • E Offline
                    eightbit @sdetweil
                    Linux raspberrypi 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                      sdetweil @eightbit
                      @eightbit you didn’t need to delete all the rest of the scripts
                        sdetweil @eightbit
                        @eightbit ok, armv7 and memory >512… hm
                        can u send me the ~/install.log
                        I want to see why it picked the run-statrt approach…
                        same userid at gmail
                        • 2 / 3
