    Brand new setup - running into some issues. libatk?
    3 Posts 2 Posters 1.8k Views 2 Watching
    • K Offline
      Kelemvor
      I had MM setup on my laptop, but I picked up an RPi3 from someone who wasn’t using theirs. I went through the steps here:
      https://docs.magicmirror.builders/getting-started/installation.html
      I’m using the “Lite” build of the version from the RPi Installer.
      The first issue I had is that Git does not appear to get installed, so when I got to step 2, it didn’t work. I had to manually install Git, which isn’t in the instructions (might want to add that).
      Anyway, I then went through the rest of the steps, but ran into a problem when I tried to start MM. After running npm run start, I got this:
      > magicmirror@2.25.0 start
      /home/kelemvor/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libatk-1.0.so.0: cannot open shared object file: No such file or directory
      Is there something I need to do to install whatever libatk is?
      Thanks.
        sdetweil @Kelemvor
        @Kelemvor you need to use the full version of the pi os. otherwise u fall into all these issues.
        it’s documented as full is required
          sdetweil @Kelemvor
          @Kelemvor then use my script to install,
          listed as 1st in the alternative install methods.
          see
