    Calendar not updating
    95 Posts 4 Posters 92.3k Views 6 Watching
      matt216 @sdetweil
      pi@magicmirror:~/MagicMirror $ cat somefile.txt | grep calendar
      [02.01.2024 14:56.40.510] [LOG]   Module helper loaded: calendar
      [02.01.2024 14:56.42.557] [LOG]   Connecting socket for: calendar
      [02.01.2024 14:56.42.558] [LOG]   Starting node helper for: calendar
      [02.01.2024 14:56.46.986] [LOG]   Create new calendarfetcher for url: https://my.cal.url - Interval: 120000
      [02.01.2024 14:57.13.099] [INFO]  Calendar-Fetcher: Broadcasting 379 events from https://my.cal.url.
      [02.01.2024 14:59.23.139] [ERROR] Calendar Error. Could not fetch calendar:  https://my.cal.url TypeError: fetch failed
        matt216 @matt216
            at Object.fetch (node:internal/deps/undici/undici:11576:11)
            at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
          cause: ConnectTimeoutError: Connect Timeout Error
              at onConnectTimeout (node:internal/deps/undici/undici:8522:28)
              at node:internal/deps/undici/undici:8480:50
              at Immediate._onImmediate (node:internal/deps/undici/undici:8511:13)
              at process.processImmediate (node:internal/timers:476:21) {
            code: 'UND_ERR_CONNECT_TIMEOUT'
        Timeout…
        Let me know if the full somefile.txt by email is still wanted.
          sdetweil @matt216
          @matt216 no… not needed…
            matt216 @sdetweil
            @sdetweil If I enter my calendar URL in to a web browser I can download the ics file fine, FYI
              sdetweil @matt216
              @matt216 yes, it was a momentary delay, which caused the timeout… trying to see why the catch() block didn’t
                sdetweil @matt216
                @matt216 can u try updating modules/default/calendar/calendarfetcher.js like this
                replace lines 58-84 with this . also added this to the issue
                		try {  /// new code here     // this will be the new line 58
                		fetch(url, { headers: headers, agent: httpsAgent })
                			.then(NodeHelper.checkFetchStatus)
                			.then((response) => response.text())
                			.then((responseData) => {
                				let data = [];
                				try {
                					data = ical.parseICS(responseData);
                					Log.debug(`parsed data=${JSON.stringify(data)}`);
                					events = CalendarFetcherUtils.filterEvents(data, {
                						excludedEvents,
                						includePastEvents,
                						maximumEntries,
                						maximumNumberOfDays
                				} catch (error) {
                					fetchFailedCallback(this, error);
                					scheduleTimer();
                					return;
                				this.broadcastEvents();
                				scheduleTimer();
                			.catch((error) => {
                				scheduleTimer();
                		}    // new code here =========
                		catch(error){
                                     console.error( "fetch for calendar url" +url + "failed error="+error.code);
                                    scheduleTimer();
                		}   // end new code =====
                  matt216 @sdetweil
                  @sdetweil Doesn’t like that - mirror won’t load. Got to pick up my little boy now, so reverted back (mirror loads ok again). Will try again and look at logs.
                    sdetweil @matt216
                    @matt216 u are replacing the whole block, right…
                    replace lines 58-84 in original with that
                    lmk
                      matt216 @matt216
                      @sdetweil can you tell I’m not a developer…?!
                      Ok, I’ve replaced the whole block, then pm2 stop all, cd ~/MagicMirror, npm start…
                      Mirror starts but still no new calendar events are showing where I would expect to be. Interestingly I can see that edits to existing events that I’ve made are showing up on the mirror, so there is some communication. Just no new events are being picked up.
                      Thanks again,
                      Matt
                      M S 2 Replies Last reply Reply Quote 0
                        matt216 @matt216
                        By existing and new events I mean with reference to the point I added the calendar server to the calendar module. That first initial sync (if that’s the right word) of the .ics file.
                          sdetweil @matt216
                          @matt216 and what do you see in the place where you npm start?
                          should NOT see the timeout error
                            matt216 @sdetweil
                            @sdetweil I do not see a timeout, no. The most unusual log entry related to the calendar is
                            [04.01.2024 16:39.21.257] [LOG] Use existing calendarfetcher for url: https://my.cal.url
                            That “existing” might imply something…?
                              sdetweil @matt216
                              @matt216 not an error… says ’ we created a fecther() at the start’… and we found it and are reusing it… just informational
                              now… lets turn on more debug
                              in the config.js
                              change
                                  logLevel: [
                                    "INFO",
                                    "LOG",
                                    "WARN",
                                    "ERROR",
                                 //   "DEBUG"
                              loglevel like that (just hit enter after the commas and before the ]
                              then add the // debug line
                              then remove the leading //
                              just makes it easier later to turn off debug by adding the // (comment it out)
                              then in MagicMirror folder again do
                              npm start >somefile.txt 2>&1
                              wait til you think it should have updated...
                              then ctrl-q
                              and then look at the somefile.txt or send it to me
                              same user id at gmail
                              (I added most of the debug output to work on calendar problems)
                              then u can comment out "DEBUG" again
                              we did change the calendar parser version this release, to fix a couple bugs I added code for, and a big change on the repeating rule handler...
                                matt216 @sdetweil
                                @sdetweil yikes, 14000 lines of calendar entries included in this one!
                                Any steer on what I’m looking for? Loads of personal info, so I won’t send over if that’s ok (no offence)
                                Matt
                                  sdetweil @matt216
                                  @matt216 well … just let you know… I don’t LOOK at any of that info… only the cal entry dates and processing… I only match by title… and I NEVER share…
                                  (we just added the cal url to output as some were confused about which calendar was sending what entries… more debug info )
                                  start of the content
                                  [04.01.2024 11:14.45.590] [DEBUG] There are 5 calendar entries.
                                  [04.01.2024 11:14.45.591] [DEBUG] Processing entry...
                                  [04.01.2024 11:14.45.594] [DEBUG] Event:
                                  then thru the next Event: is all one event, with its recurring events if any
                                  I’m interested in the events that you says don’t show up…
                                  one thing you can do is use the configured url to get the ics file
                                  to make sure the calendar provider is providing the entry
                                  if its in the ics , but not in the output, then this is a new parser problem… and I want to see the ics entry to test. all can be sent thru mail or private chat (altho chat posts are limited in size)
                                  curl -sL thaturl >someicsfile.txt
                                  ics file is just text
                                  can u find that entry
                                  can u find it in the debug output
                                    sdetweil @matt216
                                    @matt216 also, could you check
                                    ip addr
                                    and disable the IP v6 if present.
                                    in desktop, menu , preferences, pi config , network settings. may have to reboot
                                      sdetweil @matt216
                                      @matt216 also another user having trouble… his url is a shared cal , the other person owns it, but has given the secret url to the spouse for MM cal usage
                                      are any of the cals shared like this?
                                        matt216 @sdetweil
                                        @sdetweil Hi Sam.
                                        A newly created event is showing up in the debug logs, but not on the mirror display:
                                        [05.01.2024 13:22.18.330] [DEBUG] Event:
                                        {"type":"VEVENT","params":[],"created":"2024-01-05T13:20:05.000Z","end":"2024-01-06T10:00:00.000Z","dtstamp":"2024-01-05T13:20:06.000Z","start":"2024-01-06T09:00:00.000Z","datetype":"date-time","lastmodified":"2024-01-05T13:20:05.000Z","sequence":"0","summary":"test1234567","transparency":"OPAQUE","uid":"60E1B9F2-66C4-46ED-B98E-AD1A36FAB1EF","url":{"params":{"VALUE":"URI"},"val":""},"APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000"}
                                        [05.01.2024 13:22.18.330] [DEBUG] start: Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
                                        [05.01.2024 13:22.18.331] [DEBUG] end:: Sat Jan 06 2024 10:00:00 GMT+0000 (Greenwich Mean Time)
                                        [05.01.2024 13:22.18.331] [DEBUG] duration: 3600000
                                        [05.01.2024 13:22.18.331] [DEBUG] title: test1234567
                                        [05.01.2024 13:22.18.331] [DEBUG] initial tz=Europe/London
                                        [05.01.2024 13:22.18.332] [DEBUG] corrected tz=Europe/London
                                        [05.01.2024 13:22.18.332] [DEBUG] start date/time=Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
                                        [05.01.2024 13:22.18.332] [DEBUG] start offset=0
                                        [05.01.2024 13:22.18.333] [DEBUG] start date/time w tz =Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
                                        [05.01.2024 13:22.18.333] [DEBUG] event date=Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
                                        [05.01.2024 13:22.18.333] [DEBUG] event offset=0 hour=9 event date=Sat Jan 06 2024 09:00:00 GMT+0000 (Greenwich Mean Time)
                                        [05.01.2024 13:22.18.333] [DEBUG] adjustHours=0
                                        [05.01.2024 13:22.18.334] [DEBUG] Processing entry...
                                          matt216 @sdetweil
                                          @sdetweil done
                                            matt216 @sdetweil
                                            @sdetweil Not entirely sure what you mean here. This is a calendar that I own. It’s a locally hosted container service. Several devices read/write to it. It is a baikal server. I have seen several forum posts that suggest using the caldav URL adding ?export to the end to generate the ics file.
                                            • 2 / 5
