    MMM-CalendarExt3 stopped working
    14 Posts 3 Posters 5.4k Views 3 Watching
    • R
      redink
      I updated Magic Mirror today and my calendar is no longer working.
      Here’s the error that I get
      [02.01.2024 17:08.23.640] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/xxxxx/basic.ics TypeError: fetch failed
          at Object.fetch (node:internal/deps/undici/undici:11576:11)
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
        cause: ConnectTimeoutError: Connect Timeout Error
            at onConnectTimeout (node:internal/deps/undici/undici:8522:28)
            at node:internal/deps/undici/undici:8480:50
            at Immediate._onImmediate (node:internal/deps/undici/undici:8511:13)
            at process.processImmediate (node:internal/timers:476:21) {
          code: 'UND_ERR_CONNECT_TIMEOUT'
      And here’s my config
          module: "MMM-CalendarExt3",
          position: "bottom_bar",
          title: "",
            mode: "week",
            instanceId: "basicCalendar",
            locale: 'en-EN',
            weekIndex: 0,
            weeksInView: 4,
            maxEventLines: 5,
            firstDayOfWeek: 0,
            fontSize: "22px",
            eventTimeOptions: {
              hour12: false,
              hour: "2-digit",
              minute: "2-digit"
            useSymbol: false,
            calendarSet: ['School', 'Family'],
            broadcastPastEvents: true, // <= IMPORTANT to see past events
                url: "https://calendar.google.com/calendar/ical/xxxxxxxxxxxx/basic.ics",
                color: "green"
                url: "https://calendar.google.com/calendar/ical/xxxxxxxxxx%40group.calendar.google.com/public/basic.ics",
                color: "blue",
                filter: (event) =>{
                  if (event.title.search("......") > -1) {
                    return true
                  } else {
                    return false
      I tested both calendar URLs and they do download the ICS file just fine. I’d appreciate any help.
      S M 2 Replies Last reply
        sdetweil @redink
        @redink could you try the test fix here
        https://github.com/MagicMirrorOrg/MagicMirror/issues/3329#issuecomment-1874330142
        R 1 Reply Last reply
        • M
          MMRIZE @redink
          @redink It seems not related to the CX3 module, rather than deep, the default calendar fetch issue.
          • R
            redink @sdetweil
            @sdetweil I must be missing something, I don’t see what file this code should go in.
              sdetweil @redink
              @redink doah! I updated post there
              calendarfetcher.js
              Reply Quote 1
              • R
                redink @sdetweil
                @sdetweil Thank you, but that didn’t seem to help. I use this script to update MM https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh
                So, I wonder if something isn’t getting updated.
                  sdetweil @redink
                  @redink can u send me the ~/MagicMirror/installers/upgrade.log
                  ny userid at gmail
                  • R
                    redink @sdetweil
                    @sdetweil thanks for taking the time. It’s sent.
                      sdetweil @redink
                      @redink so, the upgrade went perfectly. no issues.
                      not sure what is going on yet.
                      can you show output of
                      ip addr
                      • R
                        redink @sdetweil
                        1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                            link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                            inet 127.0.0.1/8 scope host lo
                               valid_lft forever preferred_lft forever
                            inet6 ::1/128 scope host
                        2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
                            link/ether b8:27:eb:ee:09:64 brd ff:ff:ff:ff:ff:ff
                        3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
                            link/ether 00:0f:60:04:20:d4 brd ff:ff:ff:ff:ff:ff
                            inet 192.168.1.100/24 brd 192.168.1.255 scope global dynamic noprefixroute wlan0
                               valid_lft 45176sec preferred_lft 34376sec
                            inet6 fe80::3e7d:5421:775:6ad0/64 scope link
                          sdetweil @redink
                          @redink can you use the Raspi os config to turn off ipv6 addressing for this adapter?
                          one of the workarounds deals with incorrectly picking the network address to connect with given the client network…
                          • R
                            redink @sdetweil
                            @sdetweil while messing with raspi-config over ssh, magicmirror lost connection to my wifi. I had to connect a keyboard and reconnect. But, before going back to your last suggestion I did two other things. I updated pm2 (as suggested by some other post). And in the browser console I noticed that I had an error about not being able to locate “CX3_shared.mjs”. I checked the MMM-CalendarExt3 repo, and found that file CX3_Shared/CX3_shared.mjs, which for some reason wasn’t getting pulled by a git pull. I manually copied it in, and the calendar sort of started working.
                            I should have paid better attention to the documentation, because I would have seen that I needed to run git submodule update --init --recursive to update the submodule.
                            The reason I say “sort of” is because my family calendar doesn’t show some repeating events, but I need to dig deeper into that.
                            I really appreciate all your help.
                              sdetweil @redink
                              @redink the submodule problem is because you didn’t run npm install on the Ext3 module.
                              ext3 gets its events from the default calendar.
                              • R
                                redink @sdetweil
                                @sdetweil yeah, i probably just did a git pull
