    MMM-Todoist
    9 Posts 2 Posters 2.3k Views 2 Watching
      Syosse
      Hello everyone
      Unfortunately, I’ve been trying to get the Todoist module to work for weeks. When I edit the config, Magicmirror no longer starts, only the Rasperrypi desktop appears. What am I doing wrong here?
      I have also insert the other Modules to show that the other modules works only MMM-Todoist not working and when i delete the Module Magic Mirror works perfect…
      {	   module: 'clock',
      	   position: 'top_left',
      		module: 'MMM-Todoist',
      		position: 'bottom_right',	// This can be any of the regions. Best results in left or right regions.
      		header: 'Todoist', // This is optional
      		config: { // See 'Configuration options' for more information.
      			hideWhenEmpty: false,
      			accessToken: '5b1608*****************************53e',
      			maximumEntries: 60,
      			updateInterval: 10*60*1000, // Update every 10 minutes
      			fade: false,
      			// projects and/or labels is mandatory:
      			projects: [2326180937],
      			labels: [ "MagicMirror", "Important" ] // Tasks for any projects with these labels will be shown.
          module: 'MMM-MonthCalendar',
          header: "",
              updateDelay: 5,
              showAdjacentMonths: true
      Todoist APP API:
      Todoist APP Project ID:
      Thank You so much!
        sdetweil @Syosse
        @Syosse said in MMM-Todoist:
        [05.01.2024 14:32.28.049] [ERROR] (node:2061) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
        Require stack:
        • /home/Admin/MagicMirror/modules/MMM-Todoist/node_helper.js
        yep, missing library…
        do this…
        cd ~/MagicMirror/modules/MMM-Todoist
        npm install request
        note that there are 6 - 8 missing libraries. as we clean up MM from using old dead stuff to newer supported code, some of the older modules didn’t know they were using libs from our packaging… which are no longer there…
          sdetweil @Syosse
          @Syosse can you show the errors from where you start mm
          where npm start is done
            Syosse @sdetweil
            Thanks for reply
            i have run the npm run config:check:
            magicmirror@2.25.0 config:check
            node js/check_config.js
            [05.01.2024 14:11.43.042] [INFO]  Checking file...  /home/Admin/MagicMirror/config/config.js
            [05.01.2024 14:11.43.116] [INFO]  Your configuration file doesn't contain syntax
            errors :)
              Syosse @sdetweil
              @sdetweil Thanks for the replay
              i have run the command: npm run config:check
              [05.01.2024 14:11.43.042] [INFO] Checking file... /home/Admin/MagicMirror/conf ig/config.js
              [05.01.2024 14:11.43.116] [INFO] Your configuration file doesn't contain syntax errors :)
                sdetweil @Syosse
                @Syosse ok, that means its not a syntax error
                show me the output of npm start
                if you use pm2 to auto start, do this
                pm2 stop all
                cd ~/MagicMirror
                npm start
                when done with tests
                pm2 status
                and use the number of the line(usually 0)
                pm2 start 0
                  Syosse @sdetweil
                  @sdetweil said in MMM-Todoist:
                  pm2 stop all
                  cd ~/MagicMirror
                  npm start
                  pm2 status
                  pm2 start 0
                  Thanks for the Reply:
                  i have run this command:
                  pm2 stop all
                  cd ~/MagicMirror
                  npm start
                  > magicmirror@2.25.0 start
                  [05.01.2024 14:32.28.026] [LOG]   Starting MagicMirror: v2.25.0
                  [05.01.2024 14:32.28.032] [LOG]   Loading config ...
                  [05.01.2024 14:32.28.035] [DEBUG] config template file not exists, no envsubst
                  [05.01.2024 14:32.28.039] [LOG]   Loading module helpers ...
                  [05.01.2024 14:32.28.040] [LOG]   No helper found for module: MMM-SimpleLogo.
                  [05.01.2024 14:32.28.041] [LOG]   No helper found for module: compliments.
                  [05.01.2024 14:32.28.042] [LOG]   No helper found for module: MMM-Globe.
                  [05.01.2024 14:32.28.043] [LOG]   No helper found for module: clock.
                  [05.01.2024 14:32.28.049] [ERROR] (node:2061) UnhandledPromiseRejectionWarning: Error: Cannot find module 'request'
                  Require stack:
                  - /home/Admin/MagicMirror/modules/MMM-Todoist/node_helper.js
                  - /home/Admin/MagicMirror/js/app.js
                  - /home/Admin/MagicMirror/js/electron.js
                  - /home/Admin/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                      at node:internal/modules/cjs/loader:1084:15
                      at Function.<anonymous> (node:electron/js2c/browser_init:2:117576)
                      at Module._resolveFilename (/home/Admin/MagicMirror/node_modules/module-alias/index.js:49:29)
                      at node:internal/modules/cjs/loader:929:27
                      at Function._load (node:electron/js2c/asar_bundle:2:13327)
                      at Module.require (node:internal/modules/cjs/loader:1150:19)
                      at require (node:internal/modules/cjs/helpers:110:18)
                      at Object.<anonymous> (/home/Admin/MagicMirror/modules/MMM-Todoist/node_helper.js:12:17)
                      at Module._compile (node:internal/modules/cjs/loader:1271:14)
                      at Object..js (node:internal/modules/cjs/loader:1326:10)
                      at Module.load (node:internal/modules/cjs/loader:1126:32)
                      at node:internal/modules/cjs/loader:967:12
                      at loadModule (/home/Admin/MagicMirror/js/app.js:180:19)
                  (Use `electron --trace-warnings ...` to show where the warning was created)
                  [05.01.2024 14:32.28.051] [ERROR] (node:2061) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                  [2093:0105/143229.076293:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [2093:0105/143229.076702:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [2093:0105/143229.077074:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [2093:0105/143229.077350:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [2093:0105/143229.077710:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [2093:0105/143229.078018:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [2093:0105/143229.078314:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [2093:0105/143229.080174:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [2093:0105/143229.080490:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [2093:0105/143229.080861:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [2093:0105/143229.081179:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [2093:0105/143229.081474:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [2093:0105/143229.081781:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [2093:0105/143229.082085:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  Then this command: pm2 status and finally this command: pm2 start 0
                    sdetweil @Syosse
                    Require stack:
                    do this…
                    npm install request
                      Syosse @sdetweil
                      do this…
                      npm install request
                      Perfect it works!! Thanks man
                      Last thing how can i hidde the Projectname ?
                      I have added showProject: false
                      			accessToken: '5b1608a7747cccccc0162a553e',
                      			maximumEntries: 60,
                      			fade: false,
                      			showProject: false,
                        sdetweil @Syosse
                        @Syosse I do not know…
                        the code only displays the project name when showProject is set to true (the default)
