    ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf:
    26 Posts 5 Posters 12.4k Views 5 Watching
      sdetweil @fethiyetours
      @fethiyetours can u edit the module node_helper.js and change the error path like this
                          } else {   /// this is the current line 62
                              if(response.statusCode != 200)
                                  console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " statusCode " + response.statusCode);
                              else
                                  console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** ERROR ** " + error);
      I’m guessing the statuscode will be 401, unauthorized
      • E Offline
        ereborinkorppi @sdetweil
        @sdetweil sorry for the delay. I guess I posted about my 32bit test. So I installed new 32 os and MagicMirror with the script, nothing extra, no own settings. Still gives me the same error message, and like for others here it doesn’t load the weather module (in sample config file) without any extra errors. If I switch to my own config (without any 3rd party modules) it doesn’t load all of my calendars (no other errors than the gbm_wrapper) and the whole MagicMirror gets stuck. Can’t even quit it without killing it.
          sdetweil @ereborinkorppi
          @ereborinkorppi I see that error on my pi too, but it doesn’t interfere with operations.
          would you be willing to to do a backup of your system using my backup/restore scripts
          and send me the three files. to my email,
          sane userid as here at gmail
          config.js, custom.css and the module list
          to email js files you have to rename to .txt
          • G Offline
            gonzonia @sdetweil
            @sdetweil Wondering if there was a resolution here. I just did a brand new install on a Pi4b v1.5 using the script. I’ve not added any modules or changed the default config file in any way.
            During the setup, I saw this (probably unrelated)
            /usr/lib/aarch64-linux-gnu/plymouth/.so does not exist
            Splashscreen: Couldn't change theme to MagicMirror!
            don't know how to disable screen saver on labwc compositor
            I added the
            export ELECTRON_DISABLE_GPU=1
            to the mm.sh
            but had no effect.
            I noticed this in the log
            ELECTRON_ENABLE_GPU: undefined .
            and tried adding
            export ELECTRON_ENABLE_GPU =0
            but it had no effect except to change the “undefined” to “0”
              sdetweil @gonzonia
              @gonzonia
              we disabled GPU by default, to eliminate many errors, for most users
              the plymouth message from my script is because the old way doesn’t work , but i dont know yet the right way
              the error message from electron appears to be a bug, and we cant suppress it, sorry
              • G Offline
                gonzonia @sdetweil
                @sdetweil No worries. Thanks for the response.
                • 3 / 3
