    ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf:
    26 Posts 5 Posters 15.0k Views 5 Watching
    • E
      ereborinkorppi @sdetweil
      @sdetweil I will give it a go if no easier solutions available, but will take some time before I can test it. Thank you so far, will report later what happened.
      S 2 Replies Last reply
        sdetweil @ereborinkorppi
        @ereborinkorppi i just don’t know… we are not using GPU, that error is related to GPU.
        says happening in chromium, but we are not using chromium… so… at a loss.
        I see it on my pi3 in 32 bit mode, but it doesn’t stop mm…
          @ereborinkorppi sorry I hit the reject button, can u resubmit.
          E E 2 Replies Last reply
          • E
            eyesallin @sdetweil
            Hi I’m a nooby, I’m seeing the same errors in my startup but MM still runs OK. The only reason I found it was because I can’t get the MMM-OpenWeatherMapForecast to display just says loading?
            I’m wondering now if the error has nothing to do with module running.
              sdetweil @eyesallin
              @eyesallin do you see any errors from openweathermapforecast in the place you start mm
              E 1 Reply Last reply
              • E
                eyesallin @sdetweil
                Thx for responding, the only errors are
                [MMM-OpenWeatherMapForecast] 7-Jan-24 09:08 ** ERROR ** null
                ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                Warning: vkCreateInstance: Found no drivers!
                Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                at CheckVkSuccessImpl (…/…/third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                at CreateVkInstance (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                at Initialize (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                at Create (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                at operator() (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                  sdetweil @eyesallin
                  yeh not very useful, but there was an error
                  • F
                    fethiyetours
                    Thanks for information
                      sdetweil @fethiyetours
                      @fethiyetours can u edit the module node_helper.js and change the error path like this
                                          } else {   /// this is the current line 62
                                              if(response.statusCode != 200)
                                                  console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " statusCode " + response.statusCode);
                                              else
                                                  console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** ERROR ** " + error);
                      I’m guessing the statuscode will be 401, unauthorized
                      • E
                        @sdetweil sorry for the delay. I guess I posted about my 32bit test. So I installed new 32 os and MagicMirror with the script, nothing extra, no own settings. Still gives me the same error message, and like for others here it doesn’t load the weather module (in sample config file) without any extra errors. If I switch to my own config (without any 3rd party modules) it doesn’t load all of my calendars (no other errors than the gbm_wrapper) and the whole MagicMirror gets stuck. Can’t even quit it without killing it.
                          @ereborinkorppi I see that error on my pi too, but it doesn’t interfere with operations.
                          would you be willing to to do a backup of your system using my backup/restore scripts
                          https://github.com/sdetweil/MagicMirror-backup-restore
                          and send me the three files. to my email,
                          sane userid as here at gmail
                          config.js, custom.css and the module list
                          to email js files you have to rename to .txt
                          G 1 Reply Last reply
                          • G
                            gonzonia @sdetweil
                            @sdetweil Wondering if there was a resolution here. I just did a brand new install on a Pi4b v1.5 using the script. I’ve not added any modules or changed the default config file in any way.
                            During the setup, I saw this (probably unrelated)
                            /usr/lib/aarch64-linux-gnu/plymouth/.so does not exist
                            Splashscreen: Couldn't change theme to MagicMirror!
                            don't know how to disable screen saver on labwc compositor
                            I added the
                            export ELECTRON_DISABLE_GPU=1
                            to the mm.sh
                            but had no effect.
                            I noticed this in the log
                            ELECTRON_ENABLE_GPU: undefined .
                            and tried adding
                            export ELECTRON_ENABLE_GPU =0
                            but it had no effect except to change the “undefined” to “0”
                              sdetweil @gonzonia
                              @gonzonia
                              we disabled GPU by default, to eliminate many errors, for most users
                              the plymouth message from my script is because the old way doesn’t work , but i dont know yet the right way
                              the error message from electron appears to be a bug, and we cant suppress it, sorry
                              • G
                                gonzonia @sdetweil
                                @sdetweil No worries. Thanks for the response.
