    MMM Hue Lights is not updated
    39 Posts 3 Posters 18.9k Views 3 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @JoeFranz
      @JoeFranz Apologies, I cannot assist with that. Have no idea how his module works.
        JoeFranz @mumblebaj
        @mumblebaj Ok, I installed it and am trying it out. However, I would like to exclude several groups in the line “hideGroupsWithString”. How do I enter multiple groups in the line?
          @JoeFranz That feature does not work on my module currently. I need to make time to implement.
            @JoeFranz I just had a quick look at the code and the way it works is that if you have the following list of lights, Room1, Room2, Kitchen, Garden, Workshop and you select the options :
             hideSpecificGroups: true,
             hideGroupsWithString: "Room"
            Then it will exclude anything that contains the word “Room”. It does not cater for multiple input exclusions. I will see what I can do about that.
              JoeFranz @mumblebaj
              @mumblebaj This is displayed when your module is installed, no lights… :-(
              IP and userid are correct.
              mumblebajM 3 Replies Last reply Reply Quote 0
                @JoeFranz Show me your config please.
                  @JoeFranz I am working on a fix now to exclude multiple Groups/lights. Will deploy an update shortly.
                  Below is my config and it works fine. It will only display lights that are on.
                                      module: 'MMM-PhilipsHue',
                                      disabled: false,
                                      position: 'bottom_left',
                                      config:{
                                          bridgeip: "bridgeip",
                                          userid: "userid",
                                          refreshTime: 10000 * 5,
                                          lightsOrGroups: "groups",
                                          animationSpeed: 2 * 1000,
                                          showOnlyOn: true,
                                          showLabel: true,
                                          colour: true,
                                          hideGroupsWithString: ["Kitchen", "Den"]
                  The fix should be ready in the next hour. Just busy testing it.
                    @JoeFranz Fix has been deployed, You can now exclude multiple Groups
                      JoeFranz @mumblebaj
                      @mumblebaj said in MMM Hue Lights is not updated:
                      		    position: 'top_right',
                      			bridgeip: "192.168.178.xx",
                      			userid: "xxxxxxxx",
                      			colour: true
                      S mumblebajM 2 Replies Last reply Reply Quote 0
                        sdetweil @JoeFranz
                        @JoeFranz PLEASE, ALWAYS code block around config info …
                        • 3 / 4
