    MMM Hue Lights is not updated
    39 Posts 3 Posters 23.0k Views 3 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @JoeFranz
      @JoeFranz Have you tried using my version?
        JoeFranz @mumblebaj
        @mumblebaj I tried Mitch’s (https://github.com/MitchSS/MMM-Hue). That seems similar to yours. However, I have problems excluding individual rooms or zones using “hideGroupsWithString”. How do I enter multiple zones in the line?
        "hideGroupsWithString: “Entertainment Area 1”, “Garden” doesn’t work. So I haven’t let it run for a long time and don’t know if it works. But I’ll try it :-)
        mumblebajM 2 Replies Last reply Reply Quote 0
          @JoeFranz Apologies, I cannot assist with that. Have no idea how his module works.
            JoeFranz @mumblebaj
            @mumblebaj Ok, I installed it and am trying it out. However, I would like to exclude several groups in the line “hideGroupsWithString”. How do I enter multiple groups in the line?
              @JoeFranz That feature does not work on my module currently. I need to make time to implement.
                @JoeFranz I just had a quick look at the code and the way it works is that if you have the following list of lights, Room1, Room2, Kitchen, Garden, Workshop and you select the options :
                 hideSpecificGroups: true,
                 hideGroupsWithString: "Room"
                Then it will exclude anything that contains the word “Room”. It does not cater for multiple input exclusions. I will see what I can do about that.
                  JoeFranz @mumblebaj
                  @mumblebaj This is displayed when your module is installed, no lights… :-(
                  IP and userid are correct.
                  mumblebajM 3 Replies Last reply Reply Quote 0
                    @JoeFranz Show me your config please.
                      @JoeFranz I am working on a fix now to exclude multiple Groups/lights. Will deploy an update shortly.
                      Below is my config and it works fine. It will only display lights that are on.
                                          module: 'MMM-PhilipsHue',
                                          disabled: false,
                                          position: 'bottom_left',
                                          config:{
                                              bridgeip: "bridgeip",
                                              userid: "userid",
                                              refreshTime: 10000 * 5,
                                              lightsOrGroups: "groups",
                                              animationSpeed: 2 * 1000,
                                              showOnlyOn: true,
                                              showLabel: true,
                                              colour: true,
                                              hideGroupsWithString: ["Kitchen", "Den"]
                      The fix should be ready in the next hour. Just busy testing it.
                        @JoeFranz Fix has been deployed, You can now exclude multiple Groups
                          JoeFranz @mumblebaj
                          @mumblebaj said in MMM Hue Lights is not updated:
                          		    position: 'top_right',
                          			bridgeip: "192.168.178.xx",
                          			userid: "xxxxxxxx",
                          			colour: true
                          S mumblebajM 2 Replies Last reply Reply Quote 0
                            sdetweil @JoeFranz
                            @JoeFranz PLEASE, ALWAYS code block around config info …
                              @JoeFranz Please match your config with mine and it should work
                                JoeFranz @mumblebaj
                                @mumblebajI
                                did it and it works :-)
                                Now let’s see how long the display takes to update.
                                Thank you
                                  @JoeFranz From my config it checks the status of the lights every 5 minutes.
                                  You can change that at anytime in the config and restart your mirror for the change to take effect.
                                    JoeFranz @mumblebaj
                                    @mumblebaj
                                    Is that correct in your config 5x10000?
                                    On your module page it says 60x10000
                                      @JoeFranz You can set it to any time interval in milliseconds you like. I.e. 60*1000 = 1 minute etc. You can workout from there how often you would like to refresh.
                                        JoeFranz @mumblebaj
                                        @mumblebaj Ok, the good news, the module works, the lights are updated. :-)
                                        But I can’t change the time for the update, so no matter what value I enter, it always stays at around 10 minutes. :-(
                                        This is part of the current config, after 10 minutes the lights will be updated.
        refreshTime: 60 * 1000,
                                        			showOnlyOn: false,
                                          @JoeFranz Ah, there was an error in the spelling. I have updated and pushed a change. You can pull it again and restart. It should work properly.
                                            JoeFranz @mumblebaj
                                            @mumblebaj Yes, it’s working now :-) Thanks so much! :thumbs_up:
