    MMM Hue Lights is not updated
    39 Posts 3 Posters 23.0k Views 3 Watching
      JoeFranz @mumblebaj
      @mumblebaj said in MMM Hue Lights is not updated:
      @JoeFranz Show me your config please.
      		    module: 'MMM-PhilipsHue',
      		    position: 'top_right',
      			bridgeip: "192.168.178.xx",
      			userid: "xxxxxxxx",
      			colour: true
      S mumblebajM 2 Replies Last reply Reply Quote 0
        sdetweil @JoeFranz
        @JoeFranz PLEASE, ALWAYS code block around config info …
        • mumblebajM Offline
          mumblebaj Module Developer @JoeFranz
          @JoeFranz Please match your config with mine and it should work
            JoeFranz @mumblebaj
            @mumblebajI
            did it and it works :-)
            Now let’s see how long the display takes to update.
            Thank you
              @JoeFranz From my config it checks the status of the lights every 5 minutes.
              You can change that at anytime in the config and restart your mirror for the change to take effect.
                JoeFranz @mumblebaj
                @mumblebaj
                Is that correct in your config 5x10000?
                On your module page it says 60x10000
                  @JoeFranz You can set it to any time interval in milliseconds you like. I.e. 60*1000 = 1 minute etc. You can workout from there how often you would like to refresh.
                    JoeFranz @mumblebaj
                    @mumblebaj Ok, the good news, the module works, the lights are updated. :-)
                    But I can’t change the time for the update, so no matter what value I enter, it always stays at around 10 minutes. :-(
                    This is part of the current config, after 10 minutes the lights will be updated.
                                            refreshTime: 60 * 1000,
                                            lightsOrGroups: "groups",
                    			animationSpeed: 2 * 1000,
                    			showOnlyOn: false,
                      @JoeFranz Ah, there was an error in the spelling. I have updated and pushed a change. You can pull it again and restart. It should work properly.
                        JoeFranz @mumblebaj
                        @mumblebaj Yes, it’s working now :-) Thanks so much! :thumbs_up:
                          @JoeFranz No worries
