    MMM Hue Lights is not updated
    39 Posts 3 Posters 23.8k Views 3 Watching
    • mumblebajM
      mumblebaj Module Developer @JoeFranz
      @JoeFranz I just had a quick look at the code and the way it works is that if you have the following list of lights, Room1, Room2, Kitchen, Garden, Workshop and you select the options :
       hideSpecificGroups: true,
       hideGroupsWithString: "Room"
      Then it will exclude anything that contains the word “Room”. It does not cater for multiple input exclusions. I will see what I can do about that.
      J 1 Reply Last reply
        JoeFranz @mumblebaj
        @mumblebaj This is displayed when your module is installed, no lights… :-(
        IP and userid are correct.
        mumblebajM 3 Replies Last reply
        • mumblebajM
          @JoeFranz Show me your config please.
          • mumblebajM
            @JoeFranz I am working on a fix now to exclude multiple Groups/lights. Will deploy an update shortly.
            Below is my config and it works fine. It will only display lights that are on.
                                module: 'MMM-PhilipsHue',
                                disabled: false,
                                position: 'bottom_left',
                                config:{
                                    bridgeip: "bridgeip",
                                    userid: "userid",
                                    refreshTime: 10000 * 5,
                                    lightsOrGroups: "groups",
                                    animationSpeed: 2 * 1000,
                                    showOnlyOn: true,
                                    showLabel: true,
                                    colour: true,
                                    hideGroupsWithString: ["Kitchen", "Den"]
            The fix should be ready in the next hour. Just busy testing it.
            • mumblebajM
              @JoeFranz Fix has been deployed, You can now exclude multiple Groups
                JoeFranz @mumblebaj
                @mumblebaj said in MMM Hue Lights is not updated:
                		    position: 'top_right',
                			bridgeip: "192.168.178.xx",
                			userid: "xxxxxxxx",
                			colour: true
                S mumblebajM 2 Replies Last reply
                  sdetweil @JoeFranz
                  @JoeFranz PLEASE, ALWAYS code block around config info …
                  • mumblebajM
                    @JoeFranz Please match your config with mine and it should work
                      JoeFranz @mumblebaj
                      @mumblebajI
                      did it and it works :-)
                      Now let’s see how long the display takes to update.
                      Thank you
                      mumblebajM 1 Reply Last reply
                      • mumblebajM
                        @JoeFranz From my config it checks the status of the lights every 5 minutes.
                        You can change that at anytime in the config and restart your mirror for the change to take effect.
                          JoeFranz @mumblebaj
                          @mumblebaj
                          Is that correct in your config 5x10000?
                          On your module page it says 60x10000
                          • mumblebajM
                            @JoeFranz You can set it to any time interval in milliseconds you like. I.e. 60*1000 = 1 minute etc. You can workout from there how often you would like to refresh.
                              JoeFranz @mumblebaj
                              @mumblebaj Ok, the good news, the module works, the lights are updated. :-)
                              But I can’t change the time for the update, so no matter what value I enter, it always stays at around 10 minutes. :-(
                              This is part of the current config, after 10 minutes the lights will be updated.
                                                      refreshTime: 60 * 1000,
                              			showOnlyOn: false,
                              • mumblebajM
                                @JoeFranz Ah, there was an error in the spelling. I have updated and pushed a change. You can pull it again and restart. It should work properly.
                                  JoeFranz @mumblebaj
                                  @mumblebaj Yes, it’s working now :-) Thanks so much! :thumbs_up:
                                  • mumblebajM
                                    @JoeFranz No worries
