    MMM Hue Lights is not updated
    39 Posts 3 Posters 23.8k Views 3 Watching
      JoeFranz @mumblebaj
      @mumblebaj Ok, I installed it and am trying it out. However, I would like to exclude several groups in the line “hideGroupsWithString”. How do I enter multiple groups in the line?
      mumblebajM 1 Reply Last reply
      • mumblebajM
        mumblebaj Module Developer @JoeFranz
        @JoeFranz That feature does not work on my module currently. I need to make time to implement.
        • mumblebajM
          @JoeFranz I just had a quick look at the code and the way it works is that if you have the following list of lights, Room1, Room2, Kitchen, Garden, Workshop and you select the options :
           hideSpecificGroups: true,
           hideGroupsWithString: "Room"
          Then it will exclude anything that contains the word “Room”. It does not cater for multiple input exclusions. I will see what I can do about that.
          J 1 Reply Last reply
            JoeFranz @mumblebaj
            @mumblebaj This is displayed when your module is installed, no lights… :-(
            IP and userid are correct.
            mumblebajM 3 Replies Last reply
            • mumblebajM
              @JoeFranz Show me your config please.
              • mumblebajM
                @JoeFranz I am working on a fix now to exclude multiple Groups/lights. Will deploy an update shortly.
                Below is my config and it works fine. It will only display lights that are on.
                                    module: 'MMM-PhilipsHue',
                                    disabled: false,
                                    position: 'bottom_left',
                                    config:{
                                        bridgeip: "bridgeip",
                                        userid: "userid",
                                        refreshTime: 10000 * 5,
                                        lightsOrGroups: "groups",
                                        animationSpeed: 2 * 1000,
                                        showOnlyOn: true,
                                        showLabel: true,
                                        colour: true,
                                        hideGroupsWithString: ["Kitchen", "Den"]
                The fix should be ready in the next hour. Just busy testing it.
                • mumblebajM
                  @JoeFranz Fix has been deployed, You can now exclude multiple Groups
                    JoeFranz @mumblebaj
                    @mumblebaj said in MMM Hue Lights is not updated:
                    		    position: 'top_right',
                    			bridgeip: "192.168.178.xx",
                    			userid: "xxxxxxxx",
                    			colour: true
                    S mumblebajM 2 Replies Last reply
                      sdetweil @JoeFranz
                      @JoeFranz PLEASE, ALWAYS code block around config info …
                      • mumblebajM
                        @JoeFranz Please match your config with mine and it should work
                          JoeFranz @mumblebaj
                          @mumblebajI
                          did it and it works :-)
                          Now let’s see how long the display takes to update.
                          Thank you
                          • mumblebajM
                            @JoeFranz From my config it checks the status of the lights every 5 minutes.
                            You can change that at anytime in the config and restart your mirror for the change to take effect.
                              JoeFranz @mumblebaj
                              @mumblebaj
                              Is that correct in your config 5x10000?
                              On your module page it says 60x10000
                              • mumblebajM
                                @JoeFranz You can set it to any time interval in milliseconds you like. I.e. 60*1000 = 1 minute etc. You can workout from there how often you would like to refresh.
                                  JoeFranz @mumblebaj
                                  @mumblebaj Ok, the good news, the module works, the lights are updated. :-)
                                  But I can’t change the time for the update, so no matter what value I enter, it always stays at around 10 minutes. :-(
                                  This is part of the current config, after 10 minutes the lights will be updated.
                                                          refreshTime: 60 * 1000,
                                  			showOnlyOn: false,
                                  • mumblebajM
                                    @JoeFranz Ah, there was an error in the spelling. I have updated and pushed a change. You can pull it again and restart. It should work properly.
                                      JoeFranz @mumblebaj
                                      @mumblebaj Yes, it’s working now :-) Thanks so much! :thumbs_up:
                                      • mumblebajM
                                        @JoeFranz No worries
