    MMM Hue Lights is not updated
    39 Posts 3 Posters 23.8k Views 3 Watching
    • mumblebajM
      mumblebaj Module Developer @JoeFranz
      @JoeFranz I am working on a fix now to exclude multiple Groups/lights. Will deploy an update shortly.
      Below is my config and it works fine. It will only display lights that are on.
                          module: 'MMM-PhilipsHue',
                          disabled: false,
                          position: 'bottom_left',
                          config:{
                              bridgeip: "bridgeip",
                              userid: "userid",
                              refreshTime: 10000 * 5,
                              lightsOrGroups: "groups",
                              animationSpeed: 2 * 1000,
                              showOnlyOn: true,
                              showLabel: true,
                              colour: true,
                              hideSpecificGroups: true,
                              hideGroupsWithString: ["Kitchen", "Den"]
      The fix should be ready in the next hour. Just busy testing it.
      • mumblebajM
        @JoeFranz Fix has been deployed, You can now exclude multiple Groups
          JoeFranz @mumblebaj
          @mumblebaj said in MMM Hue Lights is not updated:
          @JoeFranz Show me your config please.
          		    position: 'top_right',
          			bridgeip: "192.168.178.xx",
          			userid: "xxxxxxxx",
          			colour: true
          S mumblebajM 2 Replies Last reply
            sdetweil @JoeFranz
            @JoeFranz PLEASE, ALWAYS code block around config info …
            • mumblebajM
              @JoeFranz Please match your config with mine and it should work
              J 1 Reply Last reply
                JoeFranz @mumblebaj
                @mumblebajI
                did it and it works :-)
                Now let’s see how long the display takes to update.
                Thank you
                mumblebajM 1 Reply Last reply
                • mumblebajM
                  @JoeFranz From my config it checks the status of the lights every 5 minutes.
                  You can change that at anytime in the config and restart your mirror for the change to take effect.
                    JoeFranz @mumblebaj
                    @mumblebaj
                    Is that correct in your config 5x10000?
                    On your module page it says 60x10000
                    • mumblebajM
                      @JoeFranz You can set it to any time interval in milliseconds you like. I.e. 60*1000 = 1 minute etc. You can workout from there how often you would like to refresh.
                        JoeFranz @mumblebaj
                        @mumblebaj Ok, the good news, the module works, the lights are updated. :-)
                        But I can’t change the time for the update, so no matter what value I enter, it always stays at around 10 minutes. :-(
                        This is part of the current config, after 10 minutes the lights will be updated.
                                                refreshTime: 60 * 1000,
                        			showOnlyOn: false,
                        • mumblebajM
                          @JoeFranz Ah, there was an error in the spelling. I have updated and pushed a change. You can pull it again and restart. It should work properly.
                            JoeFranz @mumblebaj
                            @mumblebaj Yes, it’s working now :-) Thanks so much! :thumbs_up:
                            • mumblebajM
                              @JoeFranz No worries
