    MMM Hue Lights is not updated
    39 Posts 3 Posters 22.5k Views 3 Watching
      @JoeFranz I always seem to have to push the button on my hue bridge whenever i add a new app to talk to those lights
        JoeFranz @sdetweil
        @sdetweil Ok, I don’t really understand. Does that mean the module no longer works with the new MM version?
        It’s the mmm-hue-lights module, not Mitch’s MMM-Hue.
        Then I’ll try that :-)
        S mumblebajM 2 Replies Last reply Reply Quote 0
          sdetweil @JoeFranz
          @JoeFranz I don’t know. never tried it.
          • mumblebajM Offline
            mumblebaj Module Developer @JoeFranz
            @JoeFranz Does your bridge have the same IP address? It could be that the IP for the bridge has changed. I added a fixed IP for my bridge to the router so that it never changes.
              JoeFranz @mumblebaj
              @mumblebaj
              Yes, the bridge still has the same address. It works for about 1-2 hours after starting, but then the display no longer updates :-(
                @JoeFranz You could try my MMM-PhilipsHue module.
                Unfortunately I am not sure what the issue is with the one you are using. Are you seeing any errors for the module popup anywhere?
                  JoeFranz @mumblebaj
                  @mumblebaj
                  No errors are displayed :-(
                    JoeFranz @mumblebaj
                    @mumblebaj How can I display errors?
                      @JoeFranz Depends on how you start your mirror. If you use npm start then you can check in the console window. If you pm2 then you can do pm2 logs and check the logs for any errors. You can also check the Developers Window, press Ctrl + shift + i keys together and check the console tab. You can filter by typing the module name in the filter box and check if there are any errors shown there. Or as suggested, you could give my module a try and see if that works for you.
                        JoeFranz @mumblebaj
                        @mumblebaj No errors are shown anywhere :-(
                          @JoeFranz Have you tried using my version?
                            JoeFranz @mumblebaj
                            @mumblebaj I tried Mitch’s (https://github.com/MitchSS/MMM-Hue). That seems similar to yours. However, I have problems excluding individual rooms or zones using “hideGroupsWithString”. How do I enter multiple zones in the line?
                            "hideGroupsWithString: “Entertainment Area 1”, “Garden” doesn’t work. So I haven’t let it run for a long time and don’t know if it works. But I’ll try it :-)
                              @JoeFranz Apologies, I cannot assist with that. Have no idea how his module works.
                                JoeFranz @mumblebaj
                                @mumblebaj Ok, I installed it and am trying it out. However, I would like to exclude several groups in the line “hideGroupsWithString”. How do I enter multiple groups in the line?
                                  @JoeFranz That feature does not work on my module currently. I need to make time to implement.
                                    @JoeFranz I just had a quick look at the code and the way it works is that if you have the following list of lights, Room1, Room2, Kitchen, Garden, Workshop and you select the options :
                                     hideSpecificGroups: true,
                                     hideGroupsWithString: "Room"
                                    Then it will exclude anything that contains the word “Room”. It does not cater for multiple input exclusions. I will see what I can do about that.
                                      JoeFranz @mumblebaj
                                      @mumblebaj This is displayed when your module is installed, no lights… :-(
                                      IP and userid are correct.
                                      mumblebajM 3 Replies Last reply Reply Quote 0
                                        @JoeFranz Show me your config please.
                                          @JoeFranz I am working on a fix now to exclude multiple Groups/lights. Will deploy an update shortly.
                                          Below is my config and it works fine. It will only display lights that are on.
                                                              module: 'MMM-PhilipsHue',
                                                              disabled: false,
                                                              position: 'bottom_left',
                                                              config:{
        bridgeip: "bridgeip",
        userid: "userid",
        refreshTime: 10000 * 5,
        lightsOrGroups: "groups",
        animationSpeed: 2 * 1000,
        showOnlyOn: true,
        showLabel: true,
        colour: true,
        hideGroupsWithString: ["Kitchen", "Den"]
                                          The fix should be ready in the next hour. Just busy testing it.
                                            @JoeFranz Fix has been deployed, You can now exclude multiple Groups
