    MMM Hue Lights is not updated
    39 Posts 3 Posters 20.2k Views 3 Watching
      sdetweil @JoeFranz
      @JoeFranz it’s not npm start mm
      it’s npm start
      if you were trying to use pm2 to start
      the
      pm2 start mm
      show the config entry for hue module, xx out any key…
        JoeFranz @sdetweil
            			module: 'mmm-hue-lights',
            			position: 'top_right', // pick whichever position you want
                			bridgeIp: '192.168.178.68',
                			user: 'xxxxxxxxxxx',
        				displayType: 'grid',
        				displayMode: 'groups',
        				minimalGrid: true,
        				minimalList: true,
        				alignment: 'center',
                			// ... and whatever else configuration options you want to use
          sdetweil @JoeFranz
          @JoeFranz seems like you should get some message
          we put in new messages this release if we couldn’t find the folder or js file that matches the module name. so that’s not it
            @JoeFranz I always seem to have to push the button on my hue bridge whenever i add a new app to talk to those lights
              JoeFranz @sdetweil
              @sdetweil Ok, I don’t really understand. Does that mean the module no longer works with the new MM version?
              It’s the mmm-hue-lights module, not Mitch’s MMM-Hue.
              Then I’ll try that :-)
              S mumblebajM 2 Replies Last reply Reply Quote 0
                sdetweil @JoeFranz
                @JoeFranz I don’t know. never tried it.
                • mumblebajM Offline
                  mumblebaj Module Developer @JoeFranz
                  @JoeFranz Does your bridge have the same IP address? It could be that the IP for the bridge has changed. I added a fixed IP for my bridge to the router so that it never changes.
                    JoeFranz @mumblebaj
                    @mumblebaj
                    Yes, the bridge still has the same address. It works for about 1-2 hours after starting, but then the display no longer updates :-(
                      @JoeFranz You could try my MMM-PhilipsHue module.
                      Unfortunately I am not sure what the issue is with the one you are using. Are you seeing any errors for the module popup anywhere?
                        JoeFranz @mumblebaj
                        @mumblebaj
                        No errors are displayed :-(
                        • 1 / 4
