    Issues with MMM-PIR
    22 Posts 7 Posters 12.9k Views 7 Watching
    • E Offline
      eyesallin @bugsounet
      @bugsounet
      Thanks for your patience, this is what i get.
      admin@garyspi:~ $ groups
      admin adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi
      admin@garyspi:~ $
        schris88
        your config looks good thus far, if you´re not getting it to run you can try my solution which is currently running like a charm
        I installed it with MMM-Pir-Sensor-light and changed the code to use wayland,
        to toggle the display on Pi5 this is working on a fresh OS install
        WAYLAND_DISPLAY=“wayland-1” wlr-randr --output HDMI-A-1 --off
        WAYLAND_DISPLAY=“wayland-1” wlr-randr --output HDMI-A-1 --on
        possible outputs HDMI-A-1 (the one right next to usb-c), HDMI-A-2
        If you monitor turns back on by itself after ~10 secs add “vc4.force_hotplug=1”(1=hmdi1 / 2=hdmi2 / 3=both) to the end of your /boot/firmware/cmdline.txt without creating a new line
        All I did was change the command in activate and deactivate display function in the node_helper.js and added the cmdline parameter (dont forget to reboot)
        • E Offline
          eyesallin @eyesallin
          @eyesallin
          I’m beginning to think that all this is Pi 5 related.
          Also changing to mode 10 as previously stated screws with the weather modules which don’t load. Remove MMM-PIR from config and everything works fine.
          It doesn’t help that I’m completely new to all this.
            schris88 @eyesallin
            @eyesallin yes it´s an “issue” with the pi5 as the os is now using wayland as graphical environment instead of x11 which was used forever, a lot of tools are written for it and now need to be updated to work with wayland. You will find a lot of scenarios where there is no updated tool or alternative for the pi5 atm. The switch was done end of 2023 so it´s very new.
            • E Offline
              eyesallin @schris88
              @schris88
              Thx for the info, I guess a lot of the modules require reworking for the Pi 5.
              Unfortunately I do not have the ability, totally new to the Pi and programming.
              • C Offline
                ChanceTime @eyesallin
                Is anyone able to get MMM-PIR successfully running on Bookworm? Feels like every option I’ve tried to turn my screen on and off after the PIR senses movement has been a struggle with no results. I’ve confirmed with tests that my sensor is working, but all the old ways to trigger the display on-off behaviour seem to not be running. I’m on a Pi4 running 12 with Wayland.
                Unfortunately I can’t go back to 11 because 10 worked like a dream, and 11 for some reason i could never successfully troubleshoot would refuse to load a taskbar in. Hardware seems to be working fine again in 12…
                I can post my config if it helps. Thanks for the hard work, bugsounet. :)
                  sdetweil @ChanceTime
                  @ChanceTime bookworm on pi4 or 5 uses a different window manager, Wayland, and requires different commands
                  you can go back to xorg by using the raspi-config command
                    diccon
                    Hi
                    I have had MMM-Pir module running perfectly for months. When I updated my RPi 3B+ to the latest updates this week the module produce the same error message
                    Pir Error Detected: EINVAL: invalid argument, write
                    I have tried reinstalling the module but no luck.
                    Any help greatly appreciated
                      sdetweil @diccon
                      @diccon which MMM-PIR?
                      bugsounetB 1 Reply Last reply Reply Quote 0
                      • bugsounetB Offline
                        bugsounet Banned @sdetweil
                        Hi, check pir_mode feature in readme readme
                        by default pir_mode is on mode 0
                        With pi 4 and pi 5, you can have EINVAL: invalid argument, write error
                        In this case
                        you have to use with pi 4: pir_mode: 1,
                        with pi 5 pir_mode: 2,
                        • 2 / 3
