    MMM-Jast 2.9.2 doesn't install on newest MM version 2.26
    6 Posts 3 Posters 1.0k Views 3 Watching
      soonerdm
      Any thoughts on how to fix this error?
      pi@raspberrypi:~/MagicMirror/modules/MMM-Jast $ npm install --only=production
      npm WARN config only Use --omit=dev to omit dev dependencies from the install.
      npm ERR! code ERESOLVE
      npm ERR! ERESOLVE could not resolve
      npm ERR!
      npm ERR! While resolving: mmm-jast@2.9.2
      npm ERR! Found: @typescript-eslint/eslint-plugin@4.33.0
      npm ERR! node_modules/@typescript-eslint/eslint-plugin
      npm ERR! dev @typescript-eslint/eslint-plugin@“^6.14.0” from the root project
      npm ERR! @typescript-eslint/eslint-plugin@“^4.7.0” from eslint-config-airbnb-typescript-prettier@4.2.0
      npm ERR! node_modules/eslint-config-airbnb-typescript-prettier
      npm ERR!
      npm ERR! Could not resolve dependency:
      npm ERR!
      npm ERR! Conflicting peer dependency: @typescript-eslint/parser@6.19.1
      npm ERR! node_modules/@typescript-eslint/parser
      npm ERR! peer @typescript-eslint/parser@“^6.0.0 || ^6.0.0-alpha” from @typescript-eslint/eslint-plugin@6.19.1
      npm ERR!
      npm ERR! Fix the upstream dependency conflict, or retry
      npm ERR! this command with --force or --legacy-peer-deps
      npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
      npm ERR!
      npm ERR!
      npm ERR! For a full report see:
      npm ERR! /home/pi/.npm/_logs/2024-01-23T15_27_25_863Z-eresolve-report.txt
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-23T15_27_25_863Z-debug-0.log
      • JalibuJ Offline
        Jalibu Module Developer @soonerdm
        Thank you @KristjanESPERANTO for providing a fix for it.
          sdetweil @soonerdm
          @soonerdm sadly the --onit=dev STILL CHECKS all the dev dependencies even tho they will not be installed… dumb
          so edit that package.json and add a 1 to the key
          devdependencies (on phone so check spelling)
          then it won’t be found during install
          lmk. I’ve done this many times.
            soonerdm @sdetweil
            @sdetweil Not sure what you mean by add a 1 to the key.
            Here is my package.json devDependancies block
             "devDependencies": {
                            "@stylistic/eslint-plugin": "^1.5.1",
                            "eslint-plugin-import": "^2.29.1",
                            "eslint-plugin-jest": "^27.6.0",
                            "eslint-plugin-jsdoc": "^46.9.1",
                            "express-basic-auth": "^1.2.1",
                            "husky": "^8.0.3",
                            "jest": "^29.7.0",
                            "jsdom": "^23.0.1",
                            "lint-staged": "^15.2.0",
                            "lodash": "^4.17.21",
                            "playwright": "^1.40.1",
                            "prettier": "^3.1.1",
                            "sinon": "^17.0.1",
                            "stylelint": "^16.1.0",
                            "stylelint-config-standard": "^36.0.0",
                            "stylelint-prettier": "^5.0.0",
                            "suncalc": "^1.9.0"
              sdetweil @soonerdm
              @soonerdm said in MMM-Jast 2.9.2 doesn't install on newest MM version 2.26:
              “devDependencies”: {
              JSON is ‘key’/‘value’ pairs
              so the ‘key’ here is
              "devDependencies"
              so make it
              "devDependencies1"
              watch out for the curved quotes before I used the code block…
                soonerdm @sdetweil
                @sdetweil Gotcha. I thought the key needed a 1. Not that we were renaming it to skip. Thank you. I understand it now.
                JalibuJ 1 Reply Last reply Reply Quote 0
                • JalibuJ Offline
