    • Search
    MagicMirror² v2.24.0 is available! For more information about this release, check out this topic.
    SOLVED Help customizing compliments
    Troubleshooting
    • Snoopy
      Snoopy last edited by
      Hey guys! new here to the forums and I need some help 😞
      Recently built my first magic mirror and I need some help customizing the compliments. I’ve editing it in my config but always find a way to mess it up and revert back to the default compliments. Some questions i have are: Can there only be 3 compliments per time of day? is it possible to add gifs to the MM?
      Here is my config so u guys can help me out 🙂 Thanks for your help in advance!
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
              port: 8080,
              ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
              language: 'en',
              timeFormat: 12,
              units: 'metric',
                              module: 'alert',
                              module: "updatenotification",
                              position: "top_bar"
                              module: 'clock',
                              position: 'top_left'
                              module: 'compliments',
                              position: 'lower_third'
                              module: 'currentweather',
                              position: 'top_right',
                                      locationID: 'xxxxxx',  //ID from http://www.openweathermap.org
                                      appid: 'xxxxxx'
                              module: 'weatherforecast',
                              header: 'Weather Forecast',
                                      appid: 'xxxxxxx'
      broberg 1 Reply Last reply Reply Quote 0
      • broberg
        broberg Project Sponsor @Snoopy last edited by
         * MIT Licensed.
        var config = {
                port: 8080,
                language: 'en',
                timeFormat: 12,
                units: 'metric',
                                module: 'alert',
                                position: "top_bar"
                                module: 'clock',
                                position: 'lower_third',
            compliments: {
                morning: [
                    'Good morning, handsome!',
                    'Enjoy your day!',
                    'How was your sleep?',
                afternoon: [
                    'Hello, beauty!',
                    'You look sexy!',
                    'Looking good today!',
                evening: [
                    'Wow, you look hot!',
                    'You look nice!',
                    'Hi, sexy!',
                                        appid: 'xxxxxx'
                                        appid: 'xxxxxxx'
        Just alter the compliments above between the two '
        add a , after each row when you add more compliments
        You can add any media you want, if you want a simple gif/jpg to display somewhere then MMM-SimpleLogo will do just that
        https://github.com/frdteknikelektro/MMM-SimpleLogo
        Snoopy 1 Reply Last reply Reply Quote 1
        • broberg
           * MIT Licensed.
          var config = {
                  port: 8080,
                  language: 'en',
                  timeFormat: 12,
                  units: 'metric',
                                  module: 'alert',
                                  position: "top_bar"
                                  module: 'clock',
              compliments: {
                  morning: [
                      'Enjoy your day!',
                  afternoon: [
                      'Hello, beauty!',
                      'You look sexy!',
                  evening: [
                      'You look nice!',
                      'Hi, sexy!',
                                          appid: 'xxxxxx'
                                          appid: 'xxxxxxx'
          • Snoopy
            Snoopy @broberg last edited by
            @broberg thanks! worked like a charm 🙂
