    how alert trigger
    alertsmodulemqtt
    15 Posts 3 Posters 5.2k Views 3 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer @fischi87
      @fischi87 Sorry, do not know where I read iobroker but Home Assistant has a MQTT integration, too.
        sdetweil @fischi87
        @fischi87 do you mean send notification? for send trigger?
        • F Offline
          fischi87 @wishmaster270
          @wishmaster270
          iobroker have also a MQTT instance. so maybe I will give it a try. but the readme looks difficult :-)
          • F Offline
            fischi87 @sdetweil
            like I wrote I want see a alert in my mirror that shows me the Washer finished washing. the question is how I can trigger the alert or maybe a notification, is also a idea. when I think about. how can I do it, do u have a idea?
              sdetweil @fischi87
              @fischi87 @wishmaster270 gave you the answer with his MQTTBridge module
              hears the mqtt message and can send a notification to the alert module.
              you configure both
              • F Offline
                fischi87 @sdetweil
                hello again, I connected now this modul with my broker but how can I send a notification to the alert model? this I don’t understand right now. maybe u or someone else can help me in this topic please?
                thanks
                  sdetweil @fischi87
                  @fischi87 yeh it’s a little bit of thinking, as it is two part
                  starting here
                  1. define the mqtt topic and an arbitrary ‘command’ word to execute when the topic is heard (mqttHook)
                  2. define the ‘command’ that has the notification and the payload (mqttNotiCommands)
                  and from the alert module doc, start here
                  F 2 Replies Last reply Reply Quote 0
                  • F Offline
                    fischi87 @sdetweil
                    first of all thank u for ur time.
                    i dont understand where i have to write down the sendnotification. i mean i can see in my broker the examples from the mqtt module but how it works now. my understanding is to write something in the config to trigger the alarm.
                    for example i use the example from the brige modul how can i use this exemple to trigger a alert? i hope u can understand me.
                    thanks
                    • F Offline
                      fischi87 @sdetweil
                      i have also a other idea. maybe it is easier to trigger the alert with the MMM-Api module? my broker have also a simple-api adapter.
                      but its still my question, how?
                        sdetweil @fischi87
                        @fischi87 YOU don’t do the sendnotification.
                        you take the data from it and configure the module to send it.
                        I was just showing you the doc for the alert.module that describes what it wants
                        a string for the notification value
                        and a object for the notification payload
                        these two things go in the command section
