    Can anyone revive AviationWX, PilotWX, or TAF
    36 Posts 3 Posters 9.8k Views 3 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @sdetweil
      @sdetweil I think it is possible with axios. Let me have a look at it. Will fork module from you and see what I can do and push a PR if it works.
        sdetweil @mumblebaj
        @mumblebaj said in Can anyone revive AviationWX, PilotWX, or TAF:
        really don’t want axios… better to get native fetch working…
        thats what I was trying. and you can use node xxx.js to test it without MM in the way…
        its ‘possible’. just all the different ‘it works like this’ didn’t work.
        there are two fetches in the node helper… one gets the gz file
        and one gets an xml file… that one should be easy, but I didn’t want to mix in the same code path
        mumblebajM 2 Replies Last reply Reply Quote 0
          @sdetweil The below code works fine. Tested it. Having issues with my system at the moment and can’t make the changes. Can you incorporate?
          async function fetchData(metarUrl, airports) {
            try {
              const response = await axios.get(metarUrl, {
                responseType: 'arraybuffer', // ensure response is treated as binary
                headers: {
                  'Accept-Encoding': 'gzip', // request gzip compression
              // Unzip the gzip response
              const unzippedData = zlib.gunzipSync(response.data).toString();
              let json_string = convert.toJson(unzippedData);
              var json = JSON.parse(json_string);
              var metarData = json.response.data.METAR;
              var airportData = new Object();
              var airports = payload.airportList.split(",").map(function (airport) {
                  airport = airport.trim();
                  return (airport.length < 4) ? "K" + airport : airport;
              airports.forEach(function (airport) {
                  metarData.forEach(function (metar) {
                      if (airport === metar.station_id) {
                          if (this.debug)
                              console.log("METAR data found for " + airport);
                          airportData[airport] = metar;
                          return; // check next airport in list
                  console.log(metarData)
            } catch (error) {
              console.error('Error fetching data:', error);
            @sdetweil I can fix the other fetch as well no issues. Give me a few on this one.
              @sdetweil Both calls working.
              try {
                          headers: {
                                  if (this.debug)
                          // console.log(metarData)
                  } catch (error) {
                  const checktype = { "Airspace_Flow_List":"Airspace_Flow", "Ground_Delay_List": "Ground_Delay", "Arrival_Departure_Delay_List": "Delay","Airport_Closure_List":"Airport" }
                  try {
                      const response = await axios.get(FAAUrl);
                      // Your further processing
                      let json_string =
                          //convert.toJson(test_data)     swap comments to use test FAA data
                          convert.toJson(response.data.toString());
                      if (this.debug)
                          console.log("json faa=" + json_string);
                      const faa_data = JSON.parse(json_string);
                      if (!Array.isArray(faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type)) {
                          // save the current entry
                          const x = faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type
                          //  init as an array
                          faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type = []
                          // add the element into the array
                          faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type.push(x)
                      // loop thru the delay types
                      faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type.forEach(t => {
                          if (t.name !== "Airspace Flow Programs") {
                              // for each the  there are two major keys, name and the list for that type
                              // get the key of the list
                              const keyname = Object.keys(t)[1]
                              // remove the "_list"  part for passing to front end
                              const key = keyname.split('_').slice(0, -1).join('_')
                              if (this.debug)
                                  console.log("key data=" + JSON.stringify(t[keyname][checktype[keyname]]) + "keyname=" + keyname + " key=" + checktype[keyname] + "\n")
                              if (!Array.isArray(t[keyname][checktype[keyname]])) {
                                  const x = t[keyname][checktype[keyname]]
                                  t[keyname][checktype[keyname]] = []
                                  t[keyname][checktype[keyname]].push(x)
                              } else {
                                  console.log("checkytype=" + checktype[keyname])
                              if (this.debug)
                                  console.log("data=" + Object.keys(faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type)[0] + " data=" + JSON.stringify(t) + " keyname=" + keyname + " key=" + key + " last part=" + JSON.stringify(t[keyname][key]) + "\n")
                              // look thru all the aaffected airports for this record type
                              t[keyname][checktype[keyname]].forEach(airport_record => {
                                  // if the airport is one the user requested
                                  if (airports.includes('K' + airport_record.ARPT)) {
                                      if (airportData['K' + airport_record.ARPT]['FAA'] == undefined)
                                          airportData['K' + airport_record.ARPT]['FAA'] = {}
                                      // save this data record
                                      airportData['K' + airport_record.ARPT]['FAA'][key] = airport_record
                      // Emitting data to Socket
                      //self.sendSocketNotification("WX_RESULT", airportData);
                  } catch (error) {
                      console.error('Error fetching FAA data:', error);
                sdetweil @mumblebaj
                @mumblebaj thx. but there is a way to not have to use zlib. I just haven’t found any that work
                  @sdetweil If you want to use fetch you can do the first call as follows.
                  try {
                      const response = await fetch(metarUrl, {
                        headers: {
                          'Accept-Encoding': 'gzip', // Request gzip compression
                      if (!response.ok) {
                        throw new Error(`HTTP error! Status: ${response.status}`);
                      // Read response body as buffer
                      const buffer = await response.buffer();
                      // Manually decompress gzip data
                      const zlib = require('zlib');
                      const decompressedData = zlib.gunzipSync(buffer).toString();
                  You could use pako.
                  const decompressedData = pako.inflate(buffer, { to: 'string' });
                    sdetweil @mumblebaj
                    @mumblebaj but… you are not supposed to have to do either
                      @sdetweil I have not seen another way. Sorry…:man_facepalming:
                      • F Offline
                        FSAHD @mumblebaj
                        @mumblebaj @sdetweil fwiw, and I don’t know if this would be any easier for the situation.
                        There is a site called avwx.rest
                        (I believe the pilot wx all was using that source)
                        It’s an API built solely for pilot data
                        You do need a key but maybe the data will be easier to pull?
                        https://avwx.docs.apiary.io/#
                        • 3 / 4
