    MMM-GooglePhotos - Just says Loading...
    1 Posts 1 Posters 361 Views 1 Watching
    • K Offline
      Kelemvor
      I followed all the instructions to install the Google Photos module. I got the json files and I think I did everything correctly. When I reboot my MM, I just get the word “Loading…” on the screen, but nothing else happens.
      When I run MM via npm, I see this in the text:
      [09.03.2024 16:15.43.513] [INFO]  Checking git for module: MMM-GooglePhotos
      [09.03.2024 16:15.43.585] [ERROR] unable to load cache [Error: ENOENT: no such file or directory, open '/home/kelemvor/MagicMirror/modules/MMM-GooglePhotos/cache/photoListCache.json'] {
        errno: -2,
        code: 'ENOENT',
        syscall: 'open',
        path: '/home/kelemvor/MagicMirror/modules/MMM-GooglePhotos/cache/photoListCache.json'
      [09.03.2024 16:15.43.585] [INFO]  Initialization complete!
      [09.03.2024 16:15.43.586] [INFO]  Start first scanning.
      [09.03.2024 16:15.43.588] [INFO]  Start Album scanning
      [09.03.2024 16:15.43.590] [INFO]  Getting album list
      Then a bit further down I see this:
      [09.03.2024 16:16.12.348] [ERROR] Trace: [GPHOTOS:CORE] request fail with URL sharedAlbums
          at GPhotos.logTrace (/home/kelemvor/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:128:13)
          at GPhotos.request (/home/kelemvor/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:169:12)
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
          at async getAlbum (/home/kelemvor/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:207:24)
          at async GPhotos.getAlbums (/home/kelemvor/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:179:18)
          at async Class.getAlbums (/home/kelemvor/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:200:15)
          at async Class.getAlbumList (/home/kelemvor/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:246:18)
          at async Class.scanJob (/home/kelemvor/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:227:5)
      [09.03.2024 16:16.12.350] [ERROR] Trace: [GPHOTOS:CORE] params {"pageSize":50,"pageToken":""}
          at GPhotos.request (/home/kelemvor/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:170:12)
      [09.03.2024 16:16.12.352] [ERROR] Trace: [GPHOTOS:CORE] data null
          at GPhotos.request (/home/kelemvor/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:171:12)
      [09.03.2024 16:16.12.361] [ERROR] Converting circular structure to JSON
          --> starting at object with constructor 'TLSSocket'
          |     property '_httpMessage' -> object with constructor 'ClientRequest'
          --- property 'socket' closes the circle
      stack:
      TypeError: Converting circular structure to JSON
          at JSON.stringify (<anonymous>)
          at error_to_string (/home/kelemvor/MagicMirror/modules/MMM-GooglePhotos/error_to_string.js:13:38)
          at GPhotos.request (/home/kelemvor/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:172:21)
      [09.03.2024 16:16.12.369] [ERROR] (node:26481) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
      (Use `electron --trace-warnings ...` to show where the warning was created)
      [09.03.2024 16:16.12.373] [ERROR] (node:26481) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 17)
      Anyone know where I can start looking to figure out what all this means?
      Thanks.
