    Module Region question
    21 Posts 3 Posters 9.9k Views 3 Watching
    • G Offline
      greedyvegan
      please forgive me if this has been covered but I’ve been looking for a week for a solution…
      is it possible to occupy the left middle and center of “top_bar”, “upper_third”, “middle_center”, “lower_third” and “bottom_bar” with multiple modules the way that bottom/top: left center and right works individually?
      I’ve used this as a template
      alt text
      I have the MMM-text-clock and MMM-WifiPassword as top right
      I have MMM- googlephotos and MMM-calendarext3, MMM-onspotify and word of the day is top left (WOTD is only visible when spotify isn’t playing)
      I put MMM-EveryNews is lower_third, because it centered the module
      the custom css file doesn’t modify the position,
      but “.region.bottom.right” works.
      I’ve tried changing the module css file, that works
      but I’m trying to avoid using that.
      do I have to add (module) to (region) and play around with the left: __px right: __px for that to work properly?
      because i’d add spofity and WOTD to the lower third with the news and move it left
      thanks for the assistance/help.
        sdetweil @greedyvegan
        @greedyvegan you can override the module css in custom.css
        each area is the same , stack top to bottom
          @greedyvegan I’m not sure what you were asking. can you be more specific? what module
          • BKeyportB Offline
            BKeyport Module Developer
            Yes. It’s possible. What you want to do is specific, but not complicated.
            Take a look at https://forum.magicmirror.builders/topic/18175/looking-for-some-help-with-positioning-modules/2?_=1710178976017
            • G Offline
              greedyvegan @BKeyport
              @BKeyport
              thank you very much.
              I now know the purpose of the display flex being inline.
              the regions are “block” by default.
              • G Offline
                greedyvegan @greedyvegan
                I’ve been having an hard time with my module/positions
                so I added borders to the regions in custom.css to help guide me
                and put “position:relative” to each module and they fall in line
                .region.top.right     {position:fixed;top:1px;right:1px;height:400px;width: 325px;border:5px solid #F00;border-radius:20px;}
                .region.top.center    {position:fixed;top:1px;left:575px;height:400px;width:325px;border:5px solid #F00;border-radius:20px;margin-left:auto;margin-right:auto}
                .region.top.left      {position:fixed;top:1px;left:1px;height:550px;width:400px;border:5px solid #F00;border-radius:20px;}
                .region.upper.third   {position:fixed;top:485px;left:410px;height:140px;width:660px;border:5px solid #F00;border-radius:20px;}
                .region.bottom.left   {position:fixed;left:1px;bottom:1px;width:350px;height:500px;border:5px solid #F00;border-radius:20px;}
                .region.bottom.right  {position:fixed;right:1px;bottom:1px;width:350px;height:500px;border:5px solid #F00;border-radius:20px;}
                .region.middle.center {position:fixed;top:905px;left:1px;width:1070px;height:680px;border:5px solid #F00;border-radius:20px;}
                .region.bottom.center {position:fixed;bottom:1px;left:540px;height:500px;width:350px;border:5px solid #F00;border-radius:20px;margin-left:auto;margin-right:auto}
                .region.lower.third   {position:fixed;top:1330px;left:1px;width:1070px;height:150px;border:5px solid #F00;border-radius:20px;}
                I put an error in my config file for the sake of the display
                I hope this helps someone
                  @greedyvegan yes, you could have put a background color too…
                  in custom.css and not needed the error…
                    @greedyvegan what is the hard time?
                    the positions are the top left edge of each, and no clip or wrap on the right or bottom
                    bottom of screen has overflow hidden
                    G 2 Replies Last reply Reply Quote 0
                    • G Offline
                      greedyvegan @sdetweil
                      @sdetweil said in Module Region question:
                      well overall, I’m not as savvy as most; but I’m reading and learning.
                      • I try to stray away from modifying the module’s css & js,
                        but I edit the module’s css then copy it to the custom css and revert the file. - the default modules, I edited the js files to stop the fading.
                      • some modules work and when I add a new one, it stops
                        (MMM-GooglePhotos & MMM-text-clock) worked, but when I added MMM-NewsAPI, they both stopped and the NewsAPI never showed up.
                      • I can’t understand the one call api thing for the weather
                      what also doesn’t work is ipWhitelist [], (address: “0.0.0.0”)
                      I read a post where you explained you never used VNC
                      i’d love to configure my mirror from my computer and not through the pi
                      the webpage always says “safari can’t open the page”
                      • I’d love to access the pi hard drive from my computer, I think that would make things easy, ssh@raspberry pi works; so I have access via terminal.
                      control shift & I via VNC truncates the screen and makes it difficult to view, at that point the pi slows down (I am using a usb drive for the pi os, but I don’t notice any speed difference)
                      I THINK the more modules or text in the config & css file I add, the slower it gets.
                      sorry to dump
                      I installed bullseye on my pi 4 because bookworm wouldn’t allow me to rotate the screen on VNC
                      • G Offline
                        forgot to add, previously when I would modify the config file, any time I would make a change and save the file, MagicMirror would quit and reopen, that doesn’t happen anymore. I have to manually refresh the mirror
                        • I have a question:
                        {module: "monopoly",
                        position: "lower_third",
                        url: "https://monopoly.com"
                        the last part of the code (url: “monopoly.com”)
                        doesn’t require a comma after it as long as the squiggly bracket closes the code?
                          @greedyvegan the trailing comma says more content follows.
                          if it’s not there, then the next thing must start something new,
                          if the thing isn’t finished, then lack of a trailing comma will produce an error ( Unexpected token)
                          in your example, after the url: “…”
                          there are no more properties in config section, so it is done, no commas required
                            @greedyvegan address/ipwhitelist are mm config properties, only
                            address:“0.0.0.0”, // means listen on all adapters, wifi and ethernet if both enabled,
                            WITHOUT having to specify the ACTUAL ip address
                            port: 8080 // default
                            so you would use your PC browser to connect to the ip address/name of the machine running mm:port number
                            http://ip_address_or_name:port
                            ipwhitelist:[] // provides a way to allow ONLY specific addresses, ON YOUR NETWORK, to connect to mm.
                            if you didn’t want your kids to connect to it for some reason.
                            to access disk and have ssh,use bitwise or winscp clients from your PC. will give use ssh window and file manager type access to files on pi
                              @greedyvegan for the developers console on mm page see here ( can do from any system w mm access)
                              https://forum.magicmirror.builders/post/90135
                                sdetweil
                                @greedyvegan on the restart on change, pm2 seems flaky there.
                                but I have only configured to watch config.js
                                to refresh w css just refresh the MM page.
                                ctrl-r on the MM content, f5 on the dev window content
                                you can do all the developers window from any pc that can get the MM screen
                                • G Offline
                                  understood, thank you
                                    @greedyvegan you can also try my MMM-Config module if you want to avoid the editing troubles of config.js
                                    https://github.com/sdetweil/MMM-Config
                                    • G Offline
                                      @sdetweil said
                                      • address:“0.0.0.0”, // means listen on all adapters, wifi and ethernet if both enabled, WITHOUT having to specify the ACTUAL ip address
                                        port: 8080 // default so you would use your PC browser to connect to the ip address/name of the machine running mm:port number
                                        http://ip_address_or_name:port ipwhitelist:[] // provides a way to allow ONLY specific addresses, ON YOUR NETWORK, to connect to mm.
                                      I’ve tried ipWhitelist “[]” and “[my ipaddress]” and nothing,
                                      but I’m going to try again
                                      • to access disk and have ssh,use bitwise or winscp clients from your PC. will give use ssh window and file manager type access to files on pi
                                      I’m going to give this a shot
                                      • on the restart on change, pm2 seems flaky there.
                                      I’ve been refreshing or closing the MM window
                                      • you can also try my MMM-Config module if you want yo avoid the editing troubles of config.js https://github.com/sdetweil/MMM-Config
                                      I’m going to try that now
                                      thanks a lot.
                                        @greedyvegan it’s
                                        address:'0.0.0.0',
                                        ipWhitelist:[]
                                        either single or double quotes
                                        then you can access from your phone or pc
                                        http://pi_ipaddress:8080
                                        my pi is called raspberrypi4
                                        so
                                        http://raspberrypi4:8080
                                        • G Offline
                                          the ip address didn’t work, the name worked this time,
                                          I put the whitelist under address like in your example
                                          thank you very much
                                            @greedyvegan the mm server ip address would be something like
                                            192.168.1.???
                                            if you do ping your name it should return the server address
