    Module Region question
    21 Posts 3 Posters 9.2k Views 3 Watching
      sdetweil @greedyvegan
      @greedyvegan you can override the module css in custom.css
      each area is the same , stack top to bottom
        @greedyvegan I’m not sure what you were asking. can you be more specific? what module
        • BKeyportB Offline
          BKeyport Module Developer
          Yes. It’s possible. What you want to do is specific, but not complicated.
          Take a look at https://forum.magicmirror.builders/topic/18175/looking-for-some-help-with-positioning-modules/2?_=1710178976017
          • G Offline
            greedyvegan @BKeyport
            @BKeyport
            thank you very much.
            I now know the purpose of the display flex being inline.
            the regions are “block” by default.
            • G Offline
              greedyvegan @greedyvegan
              I’ve been having an hard time with my module/positions
              so I added borders to the regions in custom.css to help guide me
              and put “position:relative” to each module and they fall in line
              .region.top.right     {position:fixed;top:1px;right:1px;height:400px;width: 325px;border:5px solid #F00;border-radius:20px;}
              .region.top.center    {position:fixed;top:1px;left:575px;height:400px;width:325px;border:5px solid #F00;border-radius:20px;margin-left:auto;margin-right:auto}
              .region.top.left      {position:fixed;top:1px;left:1px;height:550px;width:400px;border:5px solid #F00;border-radius:20px;}
              .region.upper.third   {position:fixed;top:485px;left:410px;height:140px;width:660px;border:5px solid #F00;border-radius:20px;}
              .region.bottom.left   {position:fixed;left:1px;bottom:1px;width:350px;height:500px;border:5px solid #F00;border-radius:20px;}
              .region.bottom.right  {position:fixed;right:1px;bottom:1px;width:350px;height:500px;border:5px solid #F00;border-radius:20px;}
              .region.middle.center {position:fixed;top:905px;left:1px;width:1070px;height:680px;border:5px solid #F00;border-radius:20px;}
              .region.bottom.center {position:fixed;bottom:1px;left:540px;height:500px;width:350px;border:5px solid #F00;border-radius:20px;margin-left:auto;margin-right:auto}
              .region.lower.third   {position:fixed;top:1330px;left:1px;width:1070px;height:150px;border:5px solid #F00;border-radius:20px;}
              I put an error in my config file for the sake of the display
              I hope this helps someone
                @greedyvegan yes, you could have put a background color too…
                in custom.css and not needed the error…
                  @greedyvegan what is the hard time?
                  the positions are the top left edge of each, and no clip or wrap on the right or bottom
                  bottom of screen has overflow hidden
                  G 2 Replies Last reply Reply Quote 0
                  • G Offline
                    greedyvegan @sdetweil
                    @sdetweil said in Module Region question:
                    well overall, I’m not as savvy as most; but I’m reading and learning.
                    • I try to stray away from modifying the module’s css & js,
                      but I edit the module’s css then copy it to the custom css and revert the file. - the default modules, I edited the js files to stop the fading.
                    • some modules work and when I add a new one, it stops
                      (MMM-GooglePhotos & MMM-text-clock) worked, but when I added MMM-NewsAPI, they both stopped and the NewsAPI never showed up.
                    • I can’t understand the one call api thing for the weather
                    what also doesn’t work is ipWhitelist [], (address: “0.0.0.0”)
                    I read a post where you explained you never used VNC
                    i’d love to configure my mirror from my computer and not through the pi
                    the webpage always says “safari can’t open the page”
                    • I’d love to access the pi hard drive from my computer, I think that would make things easy, ssh@raspberry pi works; so I have access via terminal.
                    control shift & I via VNC truncates the screen and makes it difficult to view, at that point the pi slows down (I am using a usb drive for the pi os, but I don’t notice any speed difference)
                    I THINK the more modules or text in the config & css file I add, the slower it gets.
                    sorry to dump
                    I installed bullseye on my pi 4 because bookworm wouldn’t allow me to rotate the screen on VNC
                    • G Offline
                      forgot to add, previously when I would modify the config file, any time I would make a change and save the file, MagicMirror would quit and reopen, that doesn’t happen anymore. I have to manually refresh the mirror
                      • I have a question:
                      {module: "monopoly",
                      position: "lower_third",
                      url: "https://monopoly.com"
                      the last part of the code (url: “monopoly.com”)
                      doesn’t require a comma after it as long as the squiggly bracket closes the code?
                        @greedyvegan the trailing comma says more content follows.
                        if it’s not there, then the next thing must start something new,
                        if the thing isn’t finished, then lack of a trailing comma will produce an error ( Unexpected token)
                        in your example, after the url: “…”
                        there are no more properties in config section, so it is done, no commas required
