    MMM-Wallpaper Display Refresh
    3 Posts 2 Posters 748 Views 2 Watching
    • D
      DarrenO 0
      I have the MMM-Wallpaper module installed and have it set to change the image every hour.
      This works as expected.
      What is unexpected is that find over the course of a week, the time at which the image slowly drifts out to 5 minutes or so until restart the host, which I usually do 1 min before the hour.
      Resetting at this time results in the host coming back up on the hour, give or take a few seconds, and display the first image.
      Any ideas on what I can do to rectify this time drift or is there something built into the module itself that causes this drift?
        sdetweil @DarrenO 0
        @DarrenO-0 I haven’t looked at the module code , but most load the image (delay), then start a timer for the next, then load (delay)… so the delay accumulates.
        without rewriting the module, you cannot fix this
        • D
          DarrenO 0 @sdetweil
          @sdetweil Thank you. That’s sense, I guess.
