    custom css for module question
    11 Posts 2 Posters 4.0k Views 4 Watching
    • G Offline
      greedyvegan
      is it possible to float the header of a module above it like in this image?
      as if “Palette Colors” said “New York CIty” for the weather
      I tried using the developer feature in the browser to find it but it’s not specific, it just says “.module.header”
        MMRIZE @greedyvegan
        @greedyvegan
        Like this?
        /* css/custom.css */
        .region .container .module {
          padding: 20px;
          border-radius: 10px;
          background-color: rgba(255 255 255 / 10%);
          min-width: 300px;
          position: relative;
        .module-header {
          position: absolute;
          top: -10px;
          left: 10px;
          background-color: darkslateblue;
          color: white;
          font-weight: bold;
          border: none;
          padding: 5px;
          border-radius: 5px;
        G 1 Reply Last reply Reply Quote 1
        • G Offline
          greedyvegan @MMRIZE
          @MMRIZE
          ahhhh region container
          yes, thank you
          • G Offline
            greedyvegan
            last series of questions (for today)
            are these options available?
            • move TUE, MAR 19 to the far right
            • OR eliminate “Today, tomorrow, in five days” and leave the date or vice versa
            • move event(s) like “Trash day” all the way to the right to make the row narrow
            • add an element to the bright or dimmed class
              .CX3A .dateParts literal seq_2 unit_none {text-align:right} isn’t working for me
            please and thank you
              MMRIZE @greedyvegan
              @greedyvegan
              .CX3A .cellHeaderSub {
                display: none;
              .CX3A .cellHeaderMain {
                display: flex;
                justify-content: space-between;
                width: 100%;
              /* Select one of below */
              /* To remove `relative day` identifier. */
              .CX3A  .cellHeaderMain .relativeDay {
                display: none;
              /* OR */
              /* To remove date of the cell */
              .CX3A  .cellHeaderMain .cellDate {
                display: none;
              Of course, you can use more extended selectors like these;
              .CX3A .cell:not(.today) .cellHeaderMain .cellDate { ...
              .CX3A .cell.thisMonth .cellHeaderMain .relativeDay { ...
              I can’t understand what those mean. Have you any example or sketch?
              • G Offline
                greedyvegan @MMRIZE
                1 - multi-day or single event, can I move that to the right
                to make the row narrower ? “Tuesday, March 19th” is a little redundant because the mini month tells me that.
                I understand IF a day happens to have multiple events it would create multiple rows.
                2 - this is related but unrelated to the calendar, some modules don’t have the simple {font-size: 12px;color red;} they use classes of bright and dimmed and or use “1em” for the size or “var(–color-text)”
                forgive me, I’m slowly learning CSS and command/terminal with error, repetition and trial.
                • G Offline
                  greedyvegan
                  I wanted to shrink the rows (blue paint)
                  by taking the (green) event and moving it to the right.
                  using this will give me space
                  • .CX3A .cellHeaderMain .cellDate {display: none;}
                  with the red paint, I’ve tried
                  • border-radius:15px;
                  but it doesn’t work
                    MMRIZE @greedyvegan
                    @greedyvegan said in custom css for module question:
                    As you know already, Events could be more than one. So what you want is; if there is only one event, it should be one-liner with the date(or with relative day identifier), but if there are N events, makes multi-rows.
                    Maybe if it is possible, it will not be so pretty. And the look would be similar to the default calendar module. If so, use the default calendar module instead.
                    There is no standard style guide for modules, so every module has it’s own look & feel. You have to override each style by yourself.
                    Anyway, some modules respects the style of the default modules. They might use the values those are defined in css/main.css
                    You can override some of the default styles in css/custom.css like below;
                    :root {
                      --color-text: darkorange;
                      --color-text-dimmed: darkgreen;
                      --color-text-bright: crimson;
                      --font-size: 16px;
                      --font-size-small: 12px;
                    original
                    transformed
                      MMRIZE @greedyvegan
                      border-radius:15px;
                      It needs some tricks. ;)
                      .CX3A .miniMonth .weeks.thisWeek {
                        background-color: darkolivegreen; /* I've put the color to show clearly */
                      .CX3A .miniMonth .weeks.thisWeek td:first-child {
                        /* left border round */
                        border-radius: 10px 0 0 10px;
                      .CX3A .miniMonth .weeks.thisWeek td:last-child {
                        /* right border round */
                        border-radius: 0 10px 10px 0;
                      For your blue/red directions. If it is possible or not, this module has not been designed for this. So I can’t help about it.
                      I recommend hiding empty cells to save some unnecessary (empty) lines.
                      .CX3A .cell[data-events-counts="0"] {
                        display: none;
                      original
                      transformed
                        MMRIZE @greedyvegan
                        @greedyvegan
                        Anyway I just show whether it is possible. (Yes, everything is possible… even though I hate this kind of looks…)
                        But… Is it really useful or pretty?
                        .CX3A .cellHeader {
                          width: fit-content;
                        .CX3A .cellFooter {
                          display: none;
                        .CX3A .cell[data-events-counts="1"] {
                          display: flex;
                        .CX3A .cell[data-events-counts="1"] .cellBody .fullday .event {
                          max-width: 100%;
                        • G Offline
                          greedyvegan @MMRIZE
                          thank you :raising_hands:
                          understood
                          boom!
                          what my wife wants, my wife gets lol
                          (happy wife = happy life
                          Anyway Yes, everything is possible…
                          I’m satisfied!
                          I appreciate your assistance… you’ve inspired me to learn more
