    New update, new fail
    6 Posts 3 Posters 2.5k Views 3 Watching
    • luisestradaL Offline
      luisestrada
      Hi All,
      With this new update I got a new error and I can’t get a solution. Any help is much appreciated.
      App threw an error during load
      Error: Cannot find module ‘ansis’
      > magicmirror@2.27.0 start
      Error: Cannot find module 'ansis'
      Require stack:
      - /home/pi/MagicMirror/js/logger.js
          at node:internal/modules/cjs/loader:1084:15
          at Function.<anonymous> (node:electron/js2c/browser_init:2:116646)
          at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at node:internal/modules/cjs/loader:929:27
          at Function._load (node:electron/js2c/asar_bundle:2:13327)
          at Module.require (node:internal/modules/cjs/loader:1150:19)
          at require (node:internal/modules/cjs/helpers:121:18)
          at /home/pi/MagicMirror/js/logger.js:5:19
          at Object.<anonymous> (/home/pi/MagicMirror/js/logger.js:46:2)
          at Module._compile (node:internal/modules/cjs/loader:1271:14)
          at Object..js (node:internal/modules/cjs/loader:1326:10)
          at Module.load (node:internal/modules/cjs/loader:1126:32)
          at node:internal/modules/cjs/loader:967:12
      A JavaScript error occurred in the main process
      Uncaught Exception:
      Require stack:
      Regards,
      Luis
      luisestradaL 1 Reply Last reply Reply Quote 0
        luisestrada @luisestrada
        @luisestrada said in New update, new fail:
        I was able to fix it with this
        sudo npm install ansis
        then the error was systeminformation and I did the same
        sudo npm install systeminformation
        FInally pm2 was the issue and I had to do
        sudo npm install pm2
        I also applied the following as the process requested it
        npm audit fix --force
        KristjanESPERANTOK S 2 Replies Last reply Reply Quote 0
        • KristjanESPERANTOK Offline
          KristjanESPERANTO Module Developer @luisestrada
          @luisestrada How did you run the update? git pull && npm run install-mm like in the docs?
            luisestrada @KristjanESPERANTO
            @KristjanESPERANTO I always update with the MMM-Remote module
              @luisestrada Please try the official way.
                sdetweil @luisestrada
                @luisestrada also, don’t use sudo.
