    MagicMirror no longer launches
    38 Posts 4 Posters 8.2k Views 3 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @RIKKO14
      @RIKKO14 Also, are there any errors where you start MM? If you start it using pm2 then the pm2 logs need to be checked. If NPM then check the terminal where you run npm from.
        RIKKO14 @mumblebaj
        @mumblebaj sorry I don’t anderstand what to do… can you give the scrip to write in my terminal ?
          @RIKKO14 How do you start MagicMirror?
            RIKKO14 @mumblebaj
            @mumblebaj with pm2
              @RIKKO14 You should then be able to run pm2 logs --lines 50 and that should return the details from the pm2 log. Hopefully it has any error details.
                sdetweil @mumblebaj
                @RIKKO14 because MagicMirror now uses a pm2 library inside, we have a version conflict…(I think)
                do
                sudo npm install pm2 -g
                then reboot
                  RIKKO14 @sdetweil
                  @sdetweil So, I do :
                  then I reboot my Pi but the problem stile the same, I Have this screen :
                    sdetweil @RIKKO14
                    @RIKKO14 your second screen is only the top.
                    open a terminal window and
                    do
                    pm2 stop all
                    pm2 flush
                    pm2 status
                    should show MagicMirror as the pgm to run
                    then do
                    pm2 start MagicMirror
                    wait
                    does it appear on screen?
                    if not do
                    pm2 stop all
                    pm2 logs --lines=50 >somefile.txt
                     ctrl-c to stop log output
                    show content of somefile.txt here
                    BR CAREFUL some log info will expose your calendar url…
                    edit somefile.txt and xxx out the private part.of url
                      RIKKO14 @sdetweil
                      pi@raspberrypi:~ $ pm2 stop all
                      pm2 flush
                      pm2 status
                      >>>> In-memory PM2 is out-of-date, do:
                      >>>> $ pm2 update
                      In memory PM2 version: 5.2.2
                      Local PM2 version: 5.3.1
                      [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                      [PM2] [MagicMirror](0) ✓
                      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                      │ 0  │ MagicMirror        │ fork     │ 567… │ stopped   │ 0%       │ 0b       │
                      [PM2] Flushing /home/pi/.pm2/pm2.log
                      >>>> $ pm2 update
                      [PM2] Flushing:
                      [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
                      [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
                      [PM2] Logs flushed
                      >>>> $ pm2 update
                      pi@raspberrypi:~ $ pm2 start MagicMirror
                      >>>> $ pm2 update
                      [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                      [PM2] Process successfully started
                      │ 0  │ MagicMirror        │ fork     │ 567… │ online    │ 0%       │ 2.7mb    │
                      >>>> $ pm2 update
                        sdetweil @RIKKO14
                        @RIKKO14 ok, do the
                        pm2 update as it says
                        probably have to do
                        sudo pm2 update
                        as it is installed globally in protected folders
                        • 3 / 4
