    Auto start stops working
    7 Posts 2 Posters 929 Views 2 Watching
    • P Offline
      Peter
      My MM runned fine.
      I wanted to remove a module (movielistings) and add another module (everynews) but then auto start does not work anymore.
      Replacing the config file with the old one (with movielistings) auto start works well.
      What to do?
      Peter
        sdetweil @Peter
        @Peter said in Auto start stops working:
        doing test run = true, NO updates will be applied!
        yes… upgrade is a 2 part thing
        test
        do
        you did test which doesn’t fix anything
        using the second link will DO
        but as you already did it manually, apply will bail out
        so change the word apply at the end of the second copy/paste to
        force
          sdetweil @Peter
          @Peter we need to see the output of npm start with the updated config.js
          so do this
          pm2 stop.all
          cd ~/MagicMirror
          npm start
          • P Offline
            Peter @sdetweil
            @sdetweil this is what I get:
            magicmirror@2.26.0 start
            DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
            [20.04.2024 15:23.46.108] [LOG] Starting MagicMirror: v2.26.0
            [20.04.2024 15:23.46.141] [LOG] Loading config …
            [20.04.2024 15:23.46.154] [DEBUG] config template file not exists, no envsubst
            [20.04.2024 15:23.46.173] [LOG] Loading module helpers …
            [20.04.2024 15:23.46.180] [LOG] No helper found for module: alert.
            [20.04.2024 15:23.46.309] [LOG] Initializing new module helper …
            [20.04.2024 15:23.46.312] [LOG] Module helper loaded: MMM-Pir
            [20.04.2024 15:23.46.315] [LOG] No helper found for module: clock.
            [20.04.2024 15:23.46.319] [LOG] No helper found for module: calendar_monthly.
            [20.04.2024 15:23.46.848] [LOG] Initializing new module helper …
            [20.04.2024 15:23.46.851] [LOG] Module helper loaded: calendar
            [20.04.2024 15:23.46.854] [LOG] No helper found for module: weather.
            [20.04.2024 15:23.46.856] [LOG] No helper found for module: MMM-Buienradar.
            [20.04.2024 15:23.46.874] [ERROR] (node:2607) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
            Require stack:
            • /home/mm/MagicMirror/modules/MMM-EveryNews/node_helper.js
            • /home/mm/MagicMirror/js/app.js
            • /home/mm/MagicMirror/js/electron.js
            • /home/mm/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
            • at node:internal/modules/cjs/loader:1084:15
              at Function. (node:electron/js2c/browser_init:2:116118)
              at Module._resolveFilename (/home/mm/MagicMirror/node_modules/module-alias/index.js:49:29)
              at node:internal/modules/cjs/loader:929:27
              at Function._load (node:electron/js2c/node_init:2:13357)
              at Module.require (node:internal/modules/cjs/loader:1150:19)
              at require (node:internal/modules/cjs/helpers:121:18)
              at Object. (/home/mm/MagicMirror/modules/MMM-EveryNews/node_helper.js:8:17)
              at Module._compile (node:internal/modules/cjs/loader:1271:14)
              at Object…js (node:internal/modules/cjs/loader:1326:10)
              at Module.load (node:internal/modules/cjs/loader:1126:32)
              at node:internal/modules/cjs/loader:967:12
              at loadModule (/home/mm/MagicMirror/js/app.js:181:19)
              (Use electron --trace-warnings ... to show where the warning was created)
              [20.04.2024 15:23.46.876] [ERROR] (node:2607) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
              sdetweil
              Require stack:
              yep
              see
              https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-late
              a good reason to use my upgrade script… I would have checked and fixed this
              • P Offline
                Peter @sdetweil
                @sdetweil I used your updatescript; problem still the same.
                MM works fine without EveryNews in the config, with EveryNews there is no autostart.
                mm@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                update log will be in /home/mm/MagicMirror/installers/upgrade.log
                Check current Node installation …
                Node currently installed. Checking version number.
                Minimum Node version: v20.8.0
                Installed Node version: v20.8.0
                No Node.js upgrade necessary.
                Check current NPM installation …
                NPM currently installed. Checking version number.
                Minimum npm version: V10.1.0
                Installed npm version: V10.1.0
                No npm upgrade necessary.
                saving custom.css
                upgrading from version 2.26.0 to 2.27.0
                fetching latest revisions
                there are 1 local files that are different than the master repo
                package-lock.json
                any *-lock.json files do not need to be saved
                do you want to save these files for later (Y/n)?n
                skipping restore for package-lock.json, doing test run
                Checking for modules with removed libraries
                require for request in module MMM-EveryNews not found in package.json
                bypass installing request for module MMM-EveryNews , doing test run
                updating dependencies for active modules with package.json files
                processing for module MMM-Pir please wait
                skipped processing for MMM-Pir, doing test run
                processing complete for module MMM-Pir
                processing for module MMM-Buienradar please wait
                skipped processing for MMM-Buienradar, doing test run
                processing complete for module MMM-Buienradar
                processing for module MMM-EveryNews please wait
                skipped processing for MMM-EveryNews, doing test run
                processing complete for module MMM-EveryNews
                processing for module MMM-ImagesPhotos please wait
                skipped processing for MMM-ImagesPhotos, doing test run
                processing complete for module MMM-ImagesPhotos
                restoring custom.css
                mm@raspberrypi:~ $
                  sdetweil @Peter
                  test
                  do
                  force
                  • P Offline
                    Peter @sdetweil
                    @sdetweil it works!
                    Thank you very much, you are great!
                    Peter
