    Positioning Google Photo Module
    9 Posts 2 Posters 1.3k Views 2 Watching
      synint Project Sponsor
      I have managed to set up Google Photos on my MagicMirror but I am having difficulty positioning the photos below the three items located on the top bar e.g Clock, Google Calendar and Weather. My preference would be to have the photos in the middle of the MagicMirror
      You can see below the code in the Config file I am using and I have also include a image of how the MagicMirror crrently looks. I am thinking it may have something to do with image sized in the Google Album.
      Any help or guidance would be appreciated.
      Cheers,
      John
      				module: "MMM-GooglePhotos",
      				position: "middle_center",
      				albums: ["Master"], // Set your album name. like ["My wedding", "family share", "Travle to Paris"]
      				updateInterval: 10 * 10, // minimum 10 seconds.
      				sort: "new", // "old", "random"
      				uploadAlbum: null, // Only album created by `create_uploadable_album.js`.
      				condition: {
      				fromDate: null, // Or "2018-03", RFC ... format available
      				toDate: null, // Or "2019-12-25",
      				minWidth: 800, // Or 400
      				maxWidth: 2500, // Or 8000
      				minHeight: 400, // Or 400
      				maxHeight: 800, // Or 8000
      				minWHRatio: null,
      				maxWHRatio: null,
      				// WHRatio = Width/Height ratio ( ==1 : Squared Photo,   < 1 : Portraited Photo, > 1 : Landscaped Photo)
      				showWidth: 800, // These values will be used for quality of downloaded photos to show. real size to show in your MagicMirror region is recommended.
      				showHeight: 1200,
      				timeFormat: "YYYY/MM/DD HH:mm", // Or `relative` can be used.
      This is the image I am trying to post:
      S 2 Replies Last reply
        synint Project Sponsor @sdetweil
        @sdetweil Sorry Sam should have mentioned it in the last post. I set the maxWidth and maxHeight to the mointor size which is a TV e.g. 1366px x 768px. I also changed the postion of the moduler to Fullscreen_below and re booted. I do not know if this helped but reduced my images size to less than 1366px x 768px. Does not look exactly as I originally envisaged but looks good enough. I did not chane the CSS file settings as this is beyond my knowledge but afeter looking athe CSS settings realised by changing them you can get it to look exactly how you want it. Cheers, John
          sdetweil @synint
          @synint 2 things
          1 always use a code block for config info
          paste the text
          select the text you just passed, blank line above and below
          hit the button the looks like </>
          1. comment out the size values as a test
            sdetweil @synint
            @synint is there any custom.css for this?
              Apologies for my lack of knowledge. I have commented out sizes vales using // but did not resolve the situation. I am using Geany text editor to amend the config file but but do not see a button that looks like </>. The only CSS file I can find looks like this:
              :root {
                --color-text: #999;
                --color-text-dimmed: #666;
                --color-text-bright: #fff;
                --color-background: #000;
                --font-primary: "Roboto Condensed";
                --font-secondary: "Roboto";
                --font-size: 20px;
                --font-size-xsmall: 0.75rem;
                --font-size-small: 1rem;
                --font-size-medium: 1.5rem;
                --font-size-large: 3.25rem;
                --font-size-xlarge: 3.75rem;
                --gap-body-top: 60px;
                --gap-body-right: 60px;
                --gap-body-bottom: 60px;
                --gap-body-left: 60px;
                --gap-modules: 30px;
              html {
                cursor: none;
                overflow: hidden;
                background: var(--color-background);
                user-select: none;
                font-size: var(--font-size);
              ::-webkit-scrollbar {
                display: none;
              body {
                margin: var(--gap-body-top) var(--gap-body-right) var(--gap-body-bottom) var(--gap-body-left);
                position: absolute;
                height: calc(100% - var(--gap-body-top) - var(--gap-body-bottom));
                width: calc(100% - var(--gap-body-right) - var(--gap-body-left));
                color: var(--color-text);
                font-family: var(--font-primary), sans-serif;
                font-weight: 400;
                line-height: 1.5;
                -webkit-font-smoothing: antialiased;
               * Default styles.
              .dimmed {
                color: var(--color-text-dimmed);
              .normal {
              .bright {
                color: var(--color-text-bright);
              .xsmall {
                font-size: var(--font-size-xsmall);
                line-height: 1.275;
              .small {
                font-size: var(--font-size-small);
                line-height: 1.25;
              .medium {
                font-size: var(--font-size-medium);
                line-height: 1.225;
              .large {
                font-size: var(--font-size-large);
                line-height: 1;
              .xlarge {
                font-size: var(--font-size-xlarge);
                line-height: 1;
                letter-spacing: -3px;
              .thin {
                font-family: var(--font-secondary), sans-serif;
                font-weight: 100;
              .light {
                font-weight: 300;
              .regular {
                font-weight: 400;
              .bold {
                font-weight: 700;
              .align-right {
                text-align: right;
              .align-left {
                text-align: left;
              header {
                text-transform: uppercase;
                font-family: var(--font-primary), Arial, Helvetica, sans-serif;
                font-weight: 400;
                border-bottom: 1px solid var(--color-text-dimmed);
                line-height: 15px;
                padding-bottom: 5px;
                margin-bottom: 10px;
              sup {
                font-size: 50%;
                line-height: 50%;
               * Module styles.
              .module {
                margin-bottom: var(--gap-modules);
              .module.hidden {
                pointer-events: none;
              .module:not(.hidden) {
                pointer-events: auto;
              .region.bottom .module {
                margin-top: var(--gap-modules);
                margin-bottom: 0;
              .no-wrap {
                white-space: nowrap;
                overflow: hidden;
                text-overflow: ellipsis;
              .pre-line {
                white-space: pre-line;
               * Region Definitions.
              .region {
                position: absolute;
              .region.fullscreen {
                position: absolute;
                inset: calc(-1 * var(--gap-body-top)) calc(-1 * var(--gap-body-right)) calc(-1 * var(--gap-body-bottom)) calc(-1 * var(--gap-body-left));
              .region.right {
                right: 0;
                text-align: right;
              .region.top {
                top: 0;
              .region.top.center,
              .region.bottom.center {
                left: 50%;
                transform: translateX(-50%);
              .region.top.right,
              .region.top.left,
              .region.top.center {
                top: 100%;
              .region.bottom {
                bottom: 0;
              .region.bottom.right,
              .region.bottom.center,
              .region.bottom.left {
                bottom: 100%;
              .region.bar {
                width: 100%;
                text-align: center;
              .region.third,
              .region.middle.center {
                width: 100%;
                text-align: center;
                transform: translateY(-50%);
              .region.upper.third {
                top: 33%;
                top: 50%;
              .region.lower.third {
                top: 66%;
              .region.left {
                text-align: left;
              .region table {
                width: 100%;
                border-spacing: 0;
                border-collapse: separate;
                sdetweil @synint
                @synint don’t edit our files
                all css updates go in custom.css
                if it doesn’t exist, create it
                the design is custom.css overrides anything specified before it is loaded (last)
                the paste thing is in the forum message editor
                  @sdetweil Hi Sam I now have a MagicMirror that works and would not have been possibe without your support and help which I would like to thank you for.
                    sdetweil @synint
                    @synint awesome… what made it right?
                        sdetweil @synint
                        @synint cool, thanks. that might help someone else…
