    MMM-Navigate, Issues with KY-040 rotary encoder
    15 Posts 2 Posters 2.6k Views 2 Watching
      stinkycol
      Re: [MMM-Navigate](Navigation inside MagicMirror with Rotary Encoder)
      Hi all, I am hoping for some assistance, wisdom or divine intervention before I loose my mind after struggling with my MagicMirror for several days now.
      I am trying to use a rotary encode to navigate between different pages on my MagicMirror and to prove the hardware I first just wanted to see the menu working before integrating it into the rest of the build but this simple attempt has me stuck.
      I started with a fresh install of Raspberry Pi OS (64 Bit) 15/03/2024 vintage on my Pi4 and then installed the latest version of Magic Mirror including NPT and Node.js as well as the additional development tools. Started the application and MM sparked up fine so I moved on to installing MMM-Navigate and connected the KY040 rotary encoder according to instructions via a breakout board.
      I copied the MMM-Navigate entry into my config and sparked up the MM again, i can see the menu but it doesn’t fade and no twisting or pressing of the encoder makes any impact on the menu. I then went through some of the recommended fixes, adding GPIO configs [both pull up and down] to boot/config (now located in boot/firmware/config apparently) but this didn’t help, I changed the pins used but again nothing. I then became paranoid that i maybe had a broken encoder or was reading the pin layout wrong so i installed MMM-ProfileSwitcher and used the pins connected to the encoder to trigger notifications to ProfileSwitcher and these worked as expected so i knew i had the encoder connected correctly, it worked and the pins were correct as well.
      I have also tried installing python3-rpi.gpio, python3-uinput and then added uinput to the /etc/modules list but no joy there either.
      I did notice references to MMM-Navigate having a dependency on “onoff” in several internet chats as well as and entry in node_helper.js “const Gpio = require(‘onoff’).Gpio;” so I am wondering am I missing something but i cannot find a module listed as onoff and no module dependency is listed in the write up.
      I know MMM-Navigate works for other people and now I have moved beyond my original interest in the module and just want to solve the mystery before i go mad.
      Any suggestions greatly accepted.
        sdetweil @stinkycol
        @stinkycol
        did you try adding tge line to /boot/config.txt
          stinkycol @sdetweil
          Hi, yes I tried that but when editing boot/config there was an entry inside saying it had moved to boot/firmware/config so I added it there.
          S S 2 Replies Last reply Reply Quote 0
            sdetweil @stinkycol
            @stinkycol the dependency for onoff is in the package.json, and would be loaded in the module node_modules folder during npm install
            the fact that you don’t have a black screen error indicates it is installed and I see the module has the updated postinstall step to make sure it has the correct binary level matching the electron version
            did you look at the output of npm start to verify the module loaded correctly?
              stinkycol @stinkycol
              @stinkycol This is the message i see when i try to edit boot/config:
                @sdetweil said in MMM-Navigate, Issues with KY-040 rotary encoder:
                this is what I am looking for
                when you do npm start. MagicMirror puts out message
                if you use pm2 to autolaunch MM during boot
                then the command
                pm2 logs --lines=nn
                where nn is some number of lines to display, default 15
                will display the collected logs…
                generally I recommend NOT using pm2 during module adds and reconfigures to be able to review these messages more easily.
                  stinkycol @sdetweil
                  Hi, firstly I would like to thank you for helping me out especially as i am so new to this. There are messages on the npm report but I was starting the MM from my terminal on the screen and i didn’t see the messages since the mirror started up and covered them but I have started using Putty and now i can see them. I see that there is an exception that has onoff in the message so perhaps it hasnt been loaded correctly?
                    stinkycol @sdetweil
                    @sdetweil I am using PM2 in my other build but i haven’t implemented it in this one as i just wanted to confirm the KY040 code worked before moving on to autostarting
                      sdetweil @stinkycol
                      @stinkycol pm2 has lots of commands
                      in linux the convention is commands provide help two ways
                      1. using the --help param
                      2. providing a manual page, seen with man program_name
                      pm2 status will show you what is defined and what its state is
                      you can control individual apps (I have 10 defined on one system)
                      with the number of the row that matches their name or the actual name (oops I have 3 MagicMirror apps defined in different locations, so I have to use the row number
                      pm2 stop xx
                      or if you know what they are you can stop them all
                      pm2 stop all
                      you can restart an app too
                      etc…
                        sdetweil @stinkycol
                        @stinkycol i have seen that error on other posts, and it sounds like there are some new tests on setting up the gpio pins.
                        the code wants 3 pins,
                        the node_helper code
                        		console.log('MMM-Navigate, listen on GPIO PINs (BCM): '+self.config.GPIOPins[0]+','+self.config.GPIOPins[1]+','+self.config.GPIOPins[2]);
                        		const CLK = new Gpio(self.config.GPIOPins[1], 'in', 'both',{debounceTimeout : 0 }); //BCM Pin 20
                        		const DT = new Gpio(self.config.GPIOPins[0], 'in', 'both',{debounceTimeout : 0 }); //BCM Pin 26
                        line 38		const SW = new Gpio(self.config.GPIOPins[2], 'in', 'both',{debounceTimeout : 20 }); //BCM Pin 19
                        the error is on the last, which is the one you added to the boot time config.
                        I think ‘both’ incorrect for this.
                        when you used profileswitcher, what module did you use for connecting the encoder? as that module doesn’t have a hardware component
                          stinkycol @sdetweil
                          @sdetweil I used MMM-GPIO-Notifications as i was using this on my other build to use simple buttons to swap pages.
                          On the latest run I still get the errors:
                          These are the entries in the config.js:
                          This is the npm output as i move the KY040:
                            stinkycol @sdetweil
                            @sdetweil sorry I don’t write understand how you figured that the last one was causing the issue and is this an issue with boot/firmware/config? Did this mean that I should replace the gpio in the MMM-Navigate module on config.js to the sudonyms?
                            GPIOPins:[DT, CLK, SW]
                              sdetweil @stinkycol
                              @stinkycol I looked at the line numbers reported in the stack trace dump that came along w the write error
                              I do not know what the solution is
                                stinkycol @sdetweil
                                @sdetweil OK thanks for trying
                                  sdetweil @stinkycol
                                  @stinkycol the gpio notifications module does the gpio connection differently
