    Default calendar module with iCloud calendar fetch error
    6 Posts 2 Posters 448 Views 2 Watching
      autistiii
      Hello,
      i have set up the default calendar module, including both Google and iCloud calendars. Google calendars work fine, but the iCloud calendars (synced with vdirsyncer) are not displayed and i’m getting an error message that there is a problem inside the calendar module and that i should check the logs. Here they are:
      0|mm | }
      0|mm | [2024-05-25 15:54:14.002] [ERROR] Calendar Error. Could not fetch calendar: http://ip-address/modules/calendars/c4684ce4-3887-496a-ae4a-23eab8dacbb2.ics TypeError: fetch failed
      0|mm | at Object.fetch (node:internal/deps/undici/undici:12293:11)
      0|mm | at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
      0|mm | cause: Error: connect ECONNREFUSED ip-address:80
      0|mm | at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1595:16) {
      0|mm | errno: -111,
      0|mm | code: ‘ECONNREFUSED’,
      0|mm | syscall: ‘connect’,
      0|mm | address: ‘ip-address’,
      0|mm | port: 80
      0|mm | }
      0|mm | }
      Not sure whats wrong here.
      I saw in another post (https://github.com/MagicMirrorOrg/MagicMirror/issues/3147) that I should change from “localhost” to my ip-adress or “0.0.0.0”, but that did not work for me.
      It would be awesome if someone could help me out on this one :)
        sdetweil @autistiii
        @autistiii yes
        MagicMirror is running on port 8080 or whatever is configured in the config.js
        port property
        without a port number specified, it means port 80
        http://ip_address:8080/…
          autistiii @sdetweil
          thank you for the fast response.
          however, adding the port “:8080” to the ip-address in the config file doesnt solve the issue :/
          the error message is still the same
            sdetweil @autistiii
            @autistiii said in Default calendar module with iCloud calendar fetch error:
            that error?
              autistiii @sdetweil
              yes
              cause: Error: connect ECONNREFUSED ip-adress:8080
                sdetweil @autistiii
                @autistiii what is ip_address?
                localhost?
                if NOT then you have to open up access permissions
                by changing the config.js
                address and ipWhitelist properties
