    MMM-Remote-Control Alternative
    15 Posts 4 Posters 3.8k Views 4 Watching
      sdetweil @Dennys1
      @Dennys1 as you have home assistant, and probably use mqtt for other devices
      use this
      https://github.com/Tom-Hirschberger/MMM-MQTTbridge
      and on the HA side see this, for example
      https://community.home-assistant.io/t/publish-mqtt-from-an-automation/58967
        sdetweil @Dennys1
        @Dennys1 I have another mirror project I support, and added code to auto register a device as a switch with HA . then I can turn on/off in automation.
        I use a nodered registered alexa device to trigger my ‘good night’ automation which locks the doors, turns off the lights and turns off the screen of the mirror in the hall (over mqtt)
        • BKeyportB Offline
          BKeyport Module Developer @Dennys1
          @Dennys1 Sam’s got the best idea for you. There’s other ways to do it, but that by far is the easiest.
            atwist
            I’ve actually run into the same initial issue as the author. When mmm-googleassistant and mmm-remote-control are both installed it automcially closes magicmirror.
            Any ideas?
              sdetweil @atwist
              @atwist the googleassistant author has coded it that way don’t know why.
