    MMM-Remote-Control Alternative
    15 Posts 4 Posters 6.4k Views 4 Watching
      sdetweil @Dennys1
      @bugsounet whats the deal here ?
        Dennys1
        the problem is that GoogleAssistant does not load if Remote Control is present and magic mirror is stopped, I have tried different versions of Remote Control but without success,
        the operating system is Debian version: 11 (bullseye) Kernel version: 6.1 on Raspberry
        Thank you
          sdetweil @Dennys1
          @Dennys1 I understand what is happening. I asked the GoogleAssistant author to explain why
            Dennys1
            ok, thanks for your cooperation
              sdetweil @Dennys1
              @Dennys1 I’m the moderator here
              • BKeyportB
                BKeyport Module Developer @Dennys1
                @Dennys1 What are you trying to do? I’m running most of my automation stuff outside of the MM ecosystem for sanity reasons. MMM-RemoteControl never did anything right for me.
                Reply Quote -1
                  Dennys1
                  hi,
                  I would like to make Home Assistant installed on a second Raspberry send a command to RemoteControl to go to a specific page (e.g. Page3) of MM,
                  maybe there are other ways but I don’t know them
                  S BKeyportB 3 Replies Last reply
                    sdetweil @Dennys1
                    @Dennys1 as you have home assistant, and probably use mqtt for other devices
                    use this
                    https://github.com/Tom-Hirschberger/MMM-MQTTbridge
                    and on the HA side see this, for example
                    https://community.home-assistant.io/t/publish-mqtt-from-an-automation/58967
                      sdetweil @Dennys1
                      @Dennys1 I have another mirror project I support, and added code to auto register a device as a switch with HA . then I can turn on/off in automation.
                      I use a nodered registered alexa device to trigger my ‘good night’ automation which locks the doors, turns off the lights and turns off the screen of the mirror in the hall (over mqtt)
                      • BKeyportB
                        @Dennys1 Sam’s got the best idea for you. There’s other ways to do it, but that by far is the easiest.
                        • A
                          atwist
                          I’ve actually run into the same initial issue as the author. When mmm-googleassistant and mmm-remote-control are both installed it automcially closes magicmirror.
                          Any ideas?
                            sdetweil @atwist
                            @atwist the googleassistant author has coded it that way don’t know why.
