    MMM-Remote-Control Alternative
    15 Posts 4 Posters 6.2k Views 4 Watching
      Dennys1 @Dennys1
      this is the error when remote control is enabled in config.js,If I remove it everything works fine
        sdetweil @Dennys1
        @bugsounet whats the deal here ?
          Dennys1
          the problem is that GoogleAssistant does not load if Remote Control is present and magic mirror is stopped, I have tried different versions of Remote Control but without success,
          the operating system is Debian version: 11 (bullseye) Kernel version: 6.1 on Raspberry
          Thank you
            sdetweil @Dennys1
            @Dennys1 I understand what is happening. I asked the GoogleAssistant author to explain why
              Dennys1
              ok, thanks for your cooperation
                sdetweil @Dennys1
                @Dennys1 I’m the moderator here
                • BKeyportB Offline
                  BKeyport Module Developer @Dennys1
                  @Dennys1 What are you trying to do? I’m running most of my automation stuff outside of the MM ecosystem for sanity reasons. MMM-RemoteControl never did anything right for me.
                  1 Reply Last reply Reply Quote -1
                    Dennys1
                    hi,
                    I would like to make Home Assistant installed on a second Raspberry send a command to RemoteControl to go to a specific page (e.g. Page3) of MM,
                    maybe there are other ways but I don’t know them
                    S BKeyportB 3 Replies Last reply Reply Quote 0
                      sdetweil @Dennys1
                      @Dennys1 as you have home assistant, and probably use mqtt for other devices
                      use this
                      https://github.com/Tom-Hirschberger/MMM-MQTTbridge
                      and on the HA side see this, for example
                      https://community.home-assistant.io/t/publish-mqtt-from-an-automation/58967
                        sdetweil @Dennys1
                        @Dennys1 I have another mirror project I support, and added code to auto register a device as a switch with HA . then I can turn on/off in automation.
                        I use a nodered registered alexa device to trigger my ‘good night’ automation which locks the doors, turns off the lights and turns off the screen of the mirror in the hall (over mqtt)
                        • BKeyportB Offline
                          @Dennys1 Sam’s got the best idea for you. There’s other ways to do it, but that by far is the easiest.
                            atwist
                            I’ve actually run into the same initial issue as the author. When mmm-googleassistant and mmm-remote-control are both installed it automcially closes magicmirror.
                            Any ideas?
                              sdetweil @atwist
                              @atwist the googleassistant author has coded it that way don’t know why.
