    MMM-OpenWeatherForecast Error 401
    15 Posts 4 Posters 3.5k Views 4 Watching
    • V Offline
      Vauxdvihl @sdetweil
      Here ue are
      @raspberrypi:~/MagicMirror/modules/MMM-OpenWeatherForecast $ git remote -v
      origin	https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast (fetch)
      origin	https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast (push)
      • KristjanESPERANTOK Online
        KristjanESPERANTO Module Developer @Vauxdvihl
        @Vauxdvihl Okay, so that shows us that you’re using the right fork 👍 Let’s see the part of config.js for this module (without API key, of course).
        • V Offline
          Vauxdvihl @KristjanESPERANTO
          @KristjanESPERANTO
          Thank you
          		module: "MMM-OpenWeatherForecast",
          		//header: "Wetter Berlin", // Optional header
          		classes: "default everyone",
          		disabled: false,
          			apikey: "key",
          			latitude: "51.xxxxx",
          			longitude: "-0.xxxxx",
          			iconset: "2c",
          			concise: true,
          			showWind: false,
          			displayKmhForWind: true,
          			animatedIconStartDelay: 2000,
          			label_timeFormat: "HH:mm",
          			forecastLayout: "tiled",
          			forecastHeaderText: "",
          			label_sunriseTimeFormat: "HH:mm",
          			maxHourliesToShow: 0,
          			maxDailiesToShow: 4,
          			label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"],
          • kayakbabeK Offline
            kayakbabe @Vauxdvihl
            @Vauxdvihl openweathermap discontinued their 2.5 api. so the url in the module might be wrong. Check the configuration possibilities for your module and see if you can choose the 3.0 api.
            V 1 Reply Last reply Reply Quote 2
            • V Offline
              Vauxdvihl @kayakbabe
              @kayakbabe
              I do not check your answer
              While having the default weather module running with “openweathermap” as the source for the datas, everthing runs fine.
              And the default module uses according to their css file also the 2.5.
              I was also switching the “MMM-OpenWeatherForecast” css to 3.0.
              Nothing changed
