    MMM-OpenWeatherForecast Error 401
    15 Posts 4 Posters 6.1k Views 4 Watching
    • V
      Vauxdvihl @KristjanESPERANTO
      @KristjanESPERANTO
      No…hmm i don’t know
      Can you guide me?
      Thx
      • V
        Vauxdvihl
        For this is also really spuky
        Using the default weather module with my api key
        Config “OpenweatherMap”
        Everything runs fine
        Using the “MMM-OpenWeatherMapForecast” i get the error meassage 401
        Strange…
        kayakbabeK 1 Reply Last reply Reply Quote 0
        • KristjanESPERANTOK
          KristjanESPERANTO Module Developer @Vauxdvihl
          @Vauxdvihl said in MMM-OpenWeatherForecast Error 401:
          Can you guide me?
          Try git remote -v in the module’s directory.
          • V
            @KristjanESPERANTO
            no change
            Still error
              sdetweil @Vauxdvihl
              @Vauxdvihl that command will output which repo the module came from
              please show the output
              V 1 Reply Last reply Reply Quote 1
              • V
                Vauxdvihl @sdetweil
                Here ue are
                @raspberrypi:~/MagicMirror/modules/MMM-OpenWeatherForecast $ git remote -v
                origin	https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast (fetch)
                origin	https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast (push)
                  @Vauxdvihl Okay, so that shows us that you’re using the right fork 👍 Let’s see the part of config.js for this module (without API key, of course).
                  • V
                    @KristjanESPERANTO
                    Thank you
                    		module: "MMM-OpenWeatherForecast",
                    		//header: "Wetter Berlin", // Optional header
                    		classes: "default everyone",
                    		disabled: false,
                    			apikey: "key",
                    			latitude: "51.xxxxx",
                    			longitude: "-0.xxxxx",
                    			iconset: "2c",
                    			concise: true,
                    			showWind: false,
                    			displayKmhForWind: true,
                    			animatedIconStartDelay: 2000,
                    			label_timeFormat: "HH:mm",
                    			forecastLayout: "tiled",
                    			forecastHeaderText: "",
                    			label_sunriseTimeFormat: "HH:mm",
                    			maxHourliesToShow: 0,
                    			maxDailiesToShow: 4,
                    			label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"],
                    • kayakbabeK
                      kayakbabe @Vauxdvihl
                      @Vauxdvihl openweathermap discontinued their 2.5 api. so the url in the module might be wrong. Check the configuration possibilities for your module and see if you can choose the 3.0 api.
                      V 1 Reply Last reply Reply Quote 2
                      • V
                        Vauxdvihl @kayakbabe
                        @kayakbabe
                        I do not check your answer
                        While having the default weather module running with “openweathermap” as the source for the datas, everthing runs fine.
                        And the default module uses according to their css file also the 2.5.
                        I was also switching the “MMM-OpenWeatherForecast” css to 3.0.
                        Nothing changed
