problem with update magicmirror
9 Posts 2 Posters 701 Views 2 Watching
    benoit73
    hello,
    i have a problem with magicmirror update.
    i think the repository in /etc/apt/source.list is not good but i don’t know what i write in.
    Sans-titre
    S 1 Reply Last reply Jun 14, 2024, 3:46 PM Reply Quote 0
    • S Away
      sdetweil @benoit73
      @benoit73 how did you try to update?
      what made you want to update?
      why are you using root? (sudo su)
      should be user
      NEVER use sudo for MagicMirror commands (npm, git)
      B 1 Reply Last reply Jun 14, 2024, 4:18 PM Reply Quote 0
        benoit73 @sdetweil
        OK but i just hae tried to configure one module and when i lauch npm install command it’s show npm : command not found.
        I precise i not using root
        S 1 Reply Last reply Jun 14, 2024, 4:36 PM Reply Quote 0
        • S Away
          sdetweil @benoit73
          @benoit73 where did npm go ?
          can you show output
          npm install
          thanks
          B 1 Reply Last reply Jun 14, 2024, 7:48 PM Reply Quote 0
            benoit73 @sdetweil
            Sans-titre
            B 1 Reply Last reply Jun 15, 2024, 2:02 PM Reply Quote 0
              benoit73 @benoit73
              how can i install npm ?
              S 1 Reply Last reply Jun 15, 2024, 2:07 PM Reply Quote 0
              • S Away
                sdetweil @benoit73
                @benoit73 if you were installing, my script would handle that (maybe, sometimes the system is screwed up)
                maybe my upgrade script will fix it?
                see https://github.com/sdetweil/MagicMirror_scripts
                never had it disappear before
                run the upgrade with the parm
                force
                instead of
                apply
                backup first
                see https://github.com/sdetweil/MagicMirror-backup-restore
                B 1 Reply Last reply Jun 16, 2024, 10:17 AM Reply Quote 0
                  benoit73 @sdetweil
                  @sdetweil It’s ok work it !
                  Now how can i rotate screen to 90 ° ? I don’t find the files
                  S 1 Reply Last reply Jun 16, 2024, 11:22 AM Reply Quote 0
                  • S Away
                    sdetweil @benoit73
                    @benoit73 use the desktop menu, preferences, display configuration
