    Error on rebuilding MM
    2 Posts 2 Posters 401 Views 2 Watching
    • C Offline
      coolnine98
      I get error on rebuilding MM while installing EXT-Detector.
      Here is Error:
      ool@pine64:~/MagicMirror/modules$ git clone https://github.com/bugsounet/EXT-Detector
      Cloning into ‘EXT-Detector’…
      remote: Enumerating objects: 1431, done.
      remote: Counting objects: 100% (580/580), done.
      remote: Compressing objects: 100% (304/304), done.
      remote: Total 1431 (delta 393), reused 343 (delta 274), pack-reused 851
      Receiving objects: 100% (1431/1431), 12.99 MiB | 1.89 MiB/s, done.
      Resolving deltas: 100% (889/889), done.
      cool@pine64:~/MagicMirror/modules$ cd EXT-Detector
      cool@pine64:~/MagicMirror/modules/EXT-Detector$ npm install
      npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
      EXT-Detector@2.6.1 preinstall
      installer/preinstall.sh -d ‘libmagic-dev libatlas-base-dev sox libsox-fmt-all build-essential’
      Welcome to EXT-Detector v2.6.1
      No root checking…
      Checking EXT-Detector: cool/cool
      Checking MagicMirror: cool/cool
      Checking OS…
      OS Detected: linux-gnu (ubuntu 22.04 aarch64)
      Checking all dependencies…
      All Dependencies needed are installed !
      EXT-Detector@2.6.1 postinstall
      installer/postinstall.sh -r -m -b
      Prepare snowboy library…
      Done
      Minify Main code…
      Found: 7 files to minify
      Process File: …/EXT-Detector.js
      Process File: …/node_helper.js
      Process File: …/components/lib/node/index.js
      Process File: …/components/visual.js
      Process File: …/components/snowboy.js
      Process File: …/components/porcupine.js
      Process File: …/components/lpcm16.js
      Done
      Rebuild MagicMirror…
      ✖ Rebuild Failed
      An unhandled error occurred inside electron-rebuild
      Could not detect abi for version 31.1.0 and runtime electron. Updating “node-abi” might help solve this issue if it is a new release of electron
      Error: Could not detect abi for version 31.1.0 and runtime electron. Updating “node-abi” might help solve this issue if it is a new release of electron
      at Object.getAbi (/home/cool/MagicMirror/modules/EXT-Detector/node_modules/node-abi/index.js:39:9)
      at get ABI (/home/cool/MagicMirror/modules/EXT-Detector/node_modules/@electron/rebuild/lib/rebuild.js:89:39)
      at PrebuildInstall.prebuiltModuleExists (/home/cool/MagicMirror/modules/EXT-Detector/node_modules/@electron/rebuild/lib/module-type/prebuild-install.js:59:179)
      at ModuleRebuilder.prebuildInstallNativeModuleExists (/home/cool/MagicMirror/modules/EXT-Detector/node_modules/@electron/rebuild/lib/module-rebuilder.js:70:37)
      at Rebuilder.rebuildModuleAt (/home/cool/MagicMirror/modules/EXT-Detector/node_modules/@electron/rebuild/lib/rebuild.js:143:35)
      at async Rebuilder.rebuild (/home/cool/MagicMirror/modules/EXT-Detector/node_modules/@electron/rebuild/lib/rebuild.js:115:17)
      at async /home/cool/MagicMirror/modules/EXT-Detector/node_modules/@electron/rebuild/lib/cli.js:159:9
      Rebuild Failed
      npm error code 255
      npm error path /home/cool/MagicMirror/modules/EXT-Detector
      npm error command failed
      npm error command sh -c installer/postinstall.sh -r -m -b
      npm error A complete log of this run can be found in: /home/cool/.npm/_logs/2024-07-01T14_22_52_595Z-debug-0.log
      bugsounetB 1 Reply Last reply Reply Quote 0
      • bugsounetB Offline
        bugsounet Banned @coolnine98
        Duplicate of this Topic
        Can you try this?
